Traction Off and ABS indicators still on.
Old Mar 21, 2010 | 03:44 PM
Lil Kim's Avatar
Lurking here awhile and am impressed with know how on this site. Hoping you can shed some light on a problem I am having with my 2007 Cobalt SS. Recently had the SERVICE TRACTION warning with the ABS light on at the same time, this happened about 8 weeks after dealer installed break job. I have checked with a OBD2 code reader but it shows no stored codes. Even after many starts light still on. Also disconnected battery to try and reset, no luck. Only thing not checked are the ABS sensor connections for moisture etc. Any other ideas? Thank You
Old Mar 21, 2010 | 03:47 PM
SlowBalt_06's Avatar
yea i knwo standard obd2 readers only read p-codes..but i know u- codes and different codes like that will not come up...if you have the dealer scan it with the tech2 they can pull the codes
Old Mar 21, 2010 | 04:52 PM
06G5GT's Avatar
With no codes, I'd do exactly as you suggested. Unplug each wheel speed sensor and clean the contacts. Fill with dielectric grease and reconnect.
If that doesn't do it, you'll need someone that has a scantool that can watch each wheel in real time.
Old Mar 21, 2010 | 08:13 PM
Lil Kim's Avatar
Thanks for the quick response guys. SloBalt 06 Did not realize that about the OBD2 reader, learn something every day. 06G5GT thanks for the confirmation, that's my next move. Will keep you posted. Thanks again.
Old Apr 3, 2010 | 03:23 AM
michael123's Avatar
hi LIL KIM, you are right, i am agree with you,
Old Apr 15, 2010 | 10:25 AM
Lil Kim's Avatar
Well, checked all sensors for damage, corrosion etc. and cleaned, lubricated with di-electric grease. Still no luck. warning lights still on. Also disconnected battery for 30 mins, but it did not reset.
So I guess I'll bit the bullet and have it scanned. Thanx for the ideas.
Old Apr 15, 2010 | 10:28 AM
rnjmur's Avatar
If the work was done at the dealer, I would take it back to them and make them fix it. They may have damaged one of the speed sensors while they were working on it.
Old Apr 15, 2010 | 04:07 PM
Killa702's Avatar
my ABS sensor is on and its cuz my hub bearing is messed up, since the hub bearing has the abs sensor attached to it i guess that why my light came on
maybe thats it
Old Apr 15, 2010 | 04:15 PM
madmark's Avatar
check the hub, rock it up and down, more than likely sensor is out of range
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
