Trans fluid?
Trans fluid?
Ok so I'm looking into buying a 05 supercharged off my buddy and were are replaceing the clutch cuz it stuck. Meaning that I can put it in gear and let off the clutch and rev the **** out of it and it goes nowhere. My question is what type of trans fluid do I use. I called the dealer and he said it's a special fluid and it costs 200$. Thanks
Oh I forgot to mention that it is a stick shift car
Last edited by niteninja01; Aug 28, 2009 at 03:33 PM. Reason: Automerged Doublepost
and yes the whole subframe needs to be dropped. engine needs to be supported and ac condenser/radiator/stock heat exchanger needs to be tied up. kind of a PITA
you would need to get the flywheel re-surfaced or just get a new one
http://gmtunersource.com/index.php/r...lsj-build-book
here is how to do pretty much anything to an lsj
