Trans fluid?
Old Aug 28, 2009 | 03:33 PM
niteninja01's Avatar
Trans fluid?
Ok so I'm looking into buying a 05 supercharged off my buddy and were are replaceing the clutch cuz it stuck. Meaning that I can put it in gear and let off the clutch and rev the **** out of it and it goes nowhere. My question is what type of trans fluid do I use. I called the dealer and he said it's a special fluid and it costs 200$. Thanks
Oh I forgot to mention that it is a stick shift car
Last edited by niteninja01; Aug 28, 2009 at 03:33 PM. Reason: Automerged Doublepost
Old Aug 28, 2009 | 03:35 PM
BLAZIN07SS's Avatar
I'm too JDM for you
$200???? holy ****. its a saturn fluid. you need 2 quarts for a bone dry transmission. $16 a quart
Old Aug 28, 2009 | 04:30 PM
Is there a part number that i can get? And do I have to take out the sub frame to get the tranny out to do the clutch?
Old Aug 28, 2009 | 04:42 PM
arkkornkid's Avatar
#21018899 ...don't waste your time at a chevy dealer, go to saturn
Old Aug 28, 2009 | 04:48 PM
BLAZIN07SS's Avatar
I'm too JDM for you
GM part number is 21018899
and yes the whole subframe needs to be dropped. engine needs to be supported and ac condenser/radiator/stock heat exchanger needs to be tied up. kind of a PITA
Old Aug 28, 2009 | 05:02 PM
How long does it usually take to do it? And what is a good clutch to go with?
Old Aug 28, 2009 | 05:05 PM
BLAZIN07SS's Avatar
I'm too JDM for you
usually 5-6 hours. i went with an exedy hypersingle, i love it. how much power is that 05 gonna be putting down? if its not too much, check out the GM clutch upgrade http://www.crateenginedepot.com/stor...P2301C229.aspx
you would need to get the flywheel re-surfaced or just get a new one
Old Aug 28, 2009 | 05:15 PM
Its just going to be staying stock most likely, is there a walk through on how to do the clutch?
Old Aug 28, 2009 | 05:27 PM
BLAZIN07SS's Avatar
I'm too JDM for you
http://gmtunersource.com/index.php/r...lsj-build-book
here is how to do pretty much anything to an lsj
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
Tupp
Sep 29, 2015 11:07 PM
Sep 27, 2015 08:53 PM
