Transmission issue...
Old Dec 14, 2010 | 01:27 PM
jhop16's Avatar
This morning i got in my car to pull it in the garage and it was reving up reallly high before it was really moveing at all.... I'd hit the gas and the rpms would go up but it would hardly crawl... same in reverse and I / D all the gears were the same... is this just a cold tranny?? it's been sitting for acouple days in the snow... Or is this transmission dieing??
Old Dec 14, 2010 | 01:34 PM
reddevil's Avatar
Have you checked the fluid level.. I am assuming this is auto?
Old Dec 14, 2010 | 01:41 PM
jhop16's Avatar
yah its auto and no i cant find the dip stick for it... where is it?? my truck is auto and the tranny dip stick is in the back but i know that FWD is diff
Old Dec 14, 2010 | 02:06 PM
DaBuzzard's Avatar
You won't find a dipstick for the auto trans on a Cobalt - there isn't one......
Check out this link, should give you an idea of what you need to do to check the level.
Make sure it's warmed up first or you will end up over filling it.
Old Dec 25, 2010 | 09:36 PM
jhop16's Avatar
so could fluid be the problem? and how exactly does it just loose fluid? It seems a bit hard to check with the car leveled... considering i haveto jack it up at some point
Old Dec 26, 2010 | 09:42 PM
08SSTCRD's Avatar
Might have a seal leak. Front pump seal, output shaft seal, leak between the halves of the case, ect.
RaginChopsuey
Oct 27, 2015 01:27 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
