Transmission Leak???
Old Jun 29, 2015 | 02:46 AM
megaman311's Avatar
I have searched and searched all over the web and cannot find an answer to my question. I have been super busy lately and have not had the time to check myself. Just wondering if anyone here knows of an inspection plug, hole, plate, or something for me to check inside the clutch housing for fluid. I noticed the last time I did an oil change, oil on the bottom of my trans. Did not look like motor oil.... Had almost no smell to it. No clutch slippage or hard shifting at all. I currently have 130k on stock clutch. going strong with no issues, no wheel hop either, changed my mounts at 40k miles. anyone?
Old Jun 29, 2015 | 04:23 AM
Theres no way to check it but if youve never changed it you probably should. Get some redline mt-90 i believe is the correct fluid.
Old Jun 29, 2015 | 11:33 AM
sc4door's Avatar
Looking for trans fluid or clutch fluid leak? There's an inspection hole in the front of the trans directly to the right of the engine oil filter. It has a plastic cover on it that you can pull off to see inside the bell housing to look for a clutch leak of some kind. If the actual trans fluid is what you're wanting to check, pull the driver front wheel off and there's 2 allen plugs in the side of the trans. Top is fill, bottom is drain. When you pull the top plug, the fluid should be level with the hole. As suggested, if you've never changed it, now would be a good time to do so.
Old Jun 29, 2015 | 12:02 PM
chris88z24's Avatar
Axle seal most likely. Replace both if that's the cause.
Old Jun 29, 2015 | 12:33 PM
megaman311's Avatar
Thanks sc4door! That is exactly what I was wanting to know!
Also thanks for the replies, everyone
Old Jun 29, 2015 | 02:14 PM
Staged07SS's Avatar
Administrator
Administrator
Purchase the GM trans fluid. Mt-90 is not correct.
http://www.crateenginedepot.com/Manu...72-P11005.aspx
^ this is what you want.
Old Jun 29, 2015 | 04:25 PM
chris88z24's Avatar
redline makes a 75w85 thats compatible with the ss tc fluid now as well.
Old Jun 29, 2015 | 04:26 PM
chris88z24's Avatar
Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MT-85 75W85 GL-4 Gear Oil
Old Jun 30, 2015 | 07:07 AM
Staged07SS's Avatar
Administrator
Administrator
OEM trans fluid is best people.
Old Jul 4, 2015 | 03:15 AM
megaman311's Avatar
agreed!
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
