Trying to figure out a fix for two codes...
Old Dec 12, 2010 | 06:04 PM
SCcobaltSS's Avatar
I have these codes below:
[PCM] P0121 - TP Sensor Circuit Insufficient Activity (SES) (Old) (History) (Immature)
[PCM] P1101 - Mass Air Flow Sensor Out Of Self Test Range
I have cleaned the MAF and switched out the TB to see if the codes go away. Nothing.
Both codes came on at the same time I believe.
Let me know if you any ideas.. Thanks!
Old Dec 13, 2010 | 10:36 AM
SCcobaltSS's Avatar
bump...
Old Dec 13, 2010 | 06:47 PM
Coblasts's Avatar
Could be a bad connector,check them back to and including the ECM connectors.
Old Dec 13, 2010 | 07:08 PM
yel-low's Avatar
p1101 i believe is the sc intake sensor
p0121 is a thottle body cleaning is what fixes it
Old Dec 13, 2010 | 07:19 PM
Chevycobaltss3's Avatar
Mass air flow out of range means yre hertz it outa bounds. So retune for the hertz or the more boost for colder weather.
Old Dec 13, 2010 | 07:55 PM
SCcobaltSS's Avatar
I will check that.
I switched from one then back to another. Both we clean as a whistle. lol
Retune the trims or what? Not to sure what you mean by retune the hertz...
Old Dec 14, 2010 | 09:51 AM
Hertz is used as say trim but hertz is used to tell the ecm how much airflow is coming in. So yes trims lol just retune the maf and do ve as well.
Old Dec 14, 2010 | 11:16 AM
SCcobaltSS's Avatar
I know the MAF reads in hertz I just didnt get when you said tune the hertz
My tune should be fine, I just tuned for winter not too long ago... but I will check it again.
brandon04
Oct 21, 2015 07:04 AM
Builttss
Oct 4, 2015 10:21 AM
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
