Turbo stop boosting.
Old Nov 9, 2015 | 10:28 AM
CobaltSSTC's Avatar
I start car up, idles totally normal, but hear a light whistling sound while idling and driving a little bit. The car drives fine, but no boost / maybe 2 lbs with stock turbo on 2008 Cobalt. What would cause this? No smoke, messages, or vibrations of any sort. Can someone lead me down a path or knowledge of what to look for so I can figure out what the problem is? Thank you in advance.
Old Nov 9, 2015 | 10:58 AM
So you have no CELs but it wont boost? Something doesnt add up. I would first check for boost leaks via a boost leak tester not a visual inspection.
Old Nov 11, 2015 | 05:14 PM
CobaltSSTC's Avatar
I get the P0299 code.
Old Nov 11, 2015 | 05:56 PM
https://www.cobaltss.net/forums/how-...9/#post6120333
build that and test the system, the code is for boost lower than desired.
Old Nov 12, 2015 | 08:51 AM
slapbetcommissioner's Avatar
If it's not a boost leak it's likely a map sensor or the wiring. Had the same issue and replaced the lower sensor and adjusted the wiring route seamed to fix it.
Old Nov 12, 2015 | 08:52 AM
It's possible I had a boost leak though as I replaced the lower charge pipe and intercooler at the same time and made sure it was not leaking as I went.
Old Nov 12, 2015 | 12:00 PM
user 72239's Avatar
limp mode. i used to get that, had to pull my battery each time to fix it.
Deathwish317
Jan 21, 2016 07:49 PM
Cobalt_noob
Jan 15, 2016 11:34 AM
ZxZueSxS
Nov 9, 2015 10:14 AM
firehawk618
Nov 8, 2015 06:53 PM
matthewwalsh1994@gma
Nov 5, 2015 01:22 AM
