Unlimited boost?? Need help
Old Sep 28, 2007 | 11:35 PM
ecotecbreed's Avatar
I got a strange problem since yesterday. My car boost over 12.5 psi (it is stock).
If I push it, I can reach 15 to 17 psi easily.
Also, on neutral, if I hit the pedal to the floor, it goes in boost, and it is not supposed to.
I also hear a noise coming from the front, like if a vacuum or presssure lost from something disconnected.
I looked to see if a vacuum hose could be disconnected, but I haven't found anything.
I need you help!
Old Sep 28, 2007 | 11:38 PM
an0malous's Avatar
if you rev it quickly enough youll see boost on your guage in neutral.
it could be a few things
a faulty gauge just showing you bad readings....
clogged cat causing backpressure
Old Sep 28, 2007 | 11:42 PM
Even if i go smoothly.
And this noise tells me that there is smomething wrong somewhere.
Old Sep 28, 2007 | 11:44 PM
an0malous's Avatar
thats what your dealership is for
its stock you should have no issues at all getting her fixed up
Old Sep 28, 2007 | 11:50 PM
Thing is that I don'T have any warranty since this was a totaled car...
Old Sep 28, 2007 | 11:51 PM
an0malous's Avatar
well that opens up a whole new can of worms.
Old Sep 28, 2007 | 11:53 PM
JapEatr's Avatar
South Central *********
BAd cat for sure, it will cause over boost and sounds like noise in motor from backpressure in cyl, unbolt the DP and drive it confirm
Old Sep 29, 2007 | 12:00 AM
rnjmur's Avatar
Definately sounds like a clogged cat, that is where i would start at least because it will be the least expensive thing to fix. Get a new DP and cat and put it in and see if that fixes it. If not it is time to pull the valve cover off and check your rockers and valves for damage. In the mean time I would be really easy on the car or you will cause more damage or even blow it up.
Old Sep 29, 2007 | 12:04 AM
Can I drive it around smoothly until monday? Or I could damage something?
If it would be a valve, I would hear a clicking noise??
Last edited by ecotecbreed; Sep 29, 2007 at 12:04 AM. Reason: Automerged Doublepost
Old Sep 29, 2007 | 07:32 AM
SSdan's Avatar
It's the cat. Grade A answer.
Old Sep 29, 2007 | 08:35 AM
06blackg85ss's Avatar
might not be the cat, I've had first hand experience with car's doing the same thing, ended up being a broken rocker (cam follower or whatever you want to call it) Darksun's car was doing that for a long time, swapped 3 cats, hollowed one out, changed to an XTC DP, still was diong, was boosting over 20 on a 3" pulley. Finally the car let go after a few months, ended up 4 exhaust valves weren't opening anymore and it took out the exhaust cam in the process.
Could also be the cat too though. try and find someone with a stock DP for sale, if not, just hollow the ****** out and see what that does. If you still are over boostin after that, it's probably and exhaust valve issue.
Old Sep 29, 2007 | 11:04 AM
Finally, the verdict is a cloggued cat!
I will have it being chnaged monday!
Thank you all!
Old Sep 29, 2007 | 11:17 AM
good that's the easiest problem to fix
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
