Vibration 65-75 MPH
Old Sep 17, 2008 | 12:08 PM
Evilfrog's Avatar
Vibration 65-75 MPH
I getting some Vibration in the steering wheel between 65-75 MPH. It is not consent. It doesn't seem to matter what gear I am in. Snice it's started i've had new tires put on the car and balanaced. That didn't seem to effect the issues at all.
Anyone experienced this before?
Old Sep 17, 2008 | 01:12 PM
Vetteman-sssc's Avatar
Mine did that as well at roughly the same speeds as you.
Had the alligment done and doesnt shake at all anymore (camber was off).
Or have your tires rechecked for balance if you just had them just put on.
Old Sep 17, 2008 | 01:15 PM
Bl4des's Avatar
mine does this too but i had an alignment done and balancing done and something was off but my car still does it just not nearly as bad i cant even notice it sometimes
Old Sep 17, 2008 | 02:59 PM
Evilfrog's Avatar
It was present before the new tires went on. I'll have the alignment checked. But it doesn't seem to pull either way.
Old Sep 17, 2008 | 04:50 PM
Coblasts's Avatar
Could it be the speed sensitive steering causing this issue ?
What you can do is rotate the tire to the back and see if its any better.
Could be a rim problem as well if it was there before.
Old Mar 22, 2021 | 08:49 PM
Oifvet05's Avatar
I'm having this same issue. I'm about to replace the inner and outer tie rods and struts and shocks. Then get a alignment done so keeps fingers crossed
pursuitforever
Apr 17, 2012 08:46 PM
TPM/SS
Mar 19, 2012 11:05 PM
LSCobaltlover05
Dec 14, 2009 09:18 PM
celicacobalt
Wheels and Tires
Jul 30, 2007 11:37 PM
Nichq
Jul 2, 2007 02:24 PM
