Vibration Issue
Vibration Issue
Ok before i explain my problem ill let everyone know that yes i did use the search button
Ok heres my problem, While im stopped at a light (with the car on of course) sometimes i get really bad vibrations in my seat but then when i start to excelerate the vibrations go away and also sometimes i hear a little noise coming from underneath the car. i think the exhaust maybe loose, so i jacked the car up put it on stands and looked at it really quick and didnt notice anything so im going to take it to my mechanic on tuesday to get someone who knows what there doing to look it at it. Anyone have any other ideas on what it might be?
if you are catless and dont delete the rear o2 sensor, your car will throw itself into "cat over-temp protection" which will dump more fuel at idle because it thinks the cat is not working properly and its trying to save it. when it starts to give you vibes(more like a rocking motion really), just tap the throttle lightly and it will smooth out and not throw a CEL
well i just got my car back from the mechanic, he said that the exhaust was rubbing up against the body of the car in a few places, also was rubbing against the fuel line and wore away the wrap around it he said good thing i brought it in or i would have had a bigger problem and also apparently my intake was hitting the hood of the car.... Have yet to take it for a drive but hopefully its better then it was
