Weird 4th gear speed limiter problem?
Old Nov 22, 2014 | 11:47 PM
Foximus's Avatar
So, heres an interesting problem. Out at the road course today. Car runs fine thru 1-2-3, all the way to redline, makes boost, etc. Go into 4th gear, car will go to 5k rpm / 85mph then its like it hits a speed limiter. go to 5th gear, it will get to 4500 rpm and 105mph but no more.
Already did a boost leak / vaccum leak check
Put new plugs, and a spare coil pack and ign module in tonight when I got home
Reflashed my trifecta ( I have an o6 L61, so sadly thats my only option) tune on the ECM.
Nothing makes a change. This is really bizarre and i can't make heads or tails of it. anyone have ideas?
Old Nov 23, 2014 | 05:41 PM
YelloEye's Avatar
You had it up past this before right?
Old Nov 23, 2014 | 05:57 PM
JapEatr's Avatar
South Central *********
Fuel pump
Old Nov 23, 2014 | 05:58 PM
Mr.Tozzi's Avatar
you should be able to hit close to 120mph in 4th, I used to do it on my l61, but my limiter was set to 7300rpm.
Old Nov 24, 2014 | 02:42 PM
Foximus's Avatar
yea. WOT is saying knock sensor. disabled it, going to test it tonight and see.....
Old Nov 26, 2014 | 05:36 AM
Foximus's Avatar
hard reset and unplugging the knock sensor didnt fix it.. waiting to see what t
rifecta says next...
Old Nov 26, 2014 | 07:55 AM
Terminator2's Avatar
Post a screenshot of the log showing the issue.
Old Nov 26, 2014 | 02:24 PM
Foximus's Avatar
How do you do that? I use EZ Flash to data log. I have no idea how to personally view or open those files.
Old Nov 26, 2014 | 02:47 PM
JapEatr's Avatar
im telling you your out of fuel
Old Nov 26, 2014 | 03:07 PM
Foximus's Avatar
It is the OEM pump. How hard are they to change? Its just weird the AFR was full rich the whole time. Steve just sent me a new tune to try....
Old Nov 26, 2014 | 06:26 PM
Shanedude's Avatar
Dude gets a trifecta response in a day. They are back in action now?
Old Nov 28, 2014 | 12:50 PM
09CobaltSS1's Avatar
While you could possibly be out of fuel as Vaughn mentioned, the E67 used with the L61, has the ability to limit torque vs rpm vs gear, even with a manual trans. So in other words, any gear could be limited to any rpm as desired. Granted this is a trifecta tuned vehicle, so god knows how it's setup. Either way, I'm going with either fueling, or torque limiting in the tuning acting as a rpm/speed limiter.
Old Dec 1, 2014 | 03:33 PM
Foximus's Avatar
gapped the plugs down a bit and put v4 of the tune on, its a bit better. still limiting out. Whats the best program to use to try and post data logs? I have a trifecta black box cable. but i know you cant view the logs in easy flash
Old Dec 1, 2014 | 05:15 PM
HP tuners scanner should be good even if no tuning support you can still log it. Find someone with HP tuners and data log the issue. Post screenshots of the graph showing the issue.
Old Dec 9, 2014 | 03:46 PM
Foximus's Avatar
Turned out to be the L61's overly sensitive knock sensor and a conservative tune. To make power looks like i will have to keep the knock sensor unplugged. :-\ is there any aftermarket setups for those?
Old Dec 9, 2014 | 03:49 PM
I know gizzmo makes one and theres also the knocklink
Old Dec 9, 2014 | 05:39 PM
Be careful if that is real knock it is picking up and you run with it unplugged you can kiss your motor goodbye. I wax right though knock safety rev limit.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
z28addiction
Sep 28, 2015 12:03 AM
