Wierd noise.. Out of nowhere!
Old Jul 26, 2013 | 03:29 AM
seeyaass's Avatar
What's up guys. This noise just came out of nowhere I got on the highway and once I got to about 65mph this started. It doesn't go away when the clutch is engaged or when it's in neutral. Just gets slightly quieter. And gets a little louder if I give throttle, but then goes away if I wot. If I'm cruising at a steady speed it stays.. It's a faint whining...
Help! Any ideas?
2A0267E4-F0D0-4DC6-AF39-29D05FF0ABC9-235-000000134AE839B1_zps3f000a5a.mp4
Old Jul 26, 2013 | 03:32 AM
seeyaass's Avatar
If the above post don't work try this one
http://i72.photobucket.com/albums/i1...ps3f000a5a.mp4
Old Jul 26, 2013 | 02:20 PM
seeyaass's Avatar
Bump?
Old Jul 26, 2013 | 02:41 PM
user 72239's Avatar
That sounds like wheel bearings to me
Old Jul 26, 2013 | 05:35 PM
tomj77's Avatar
Here is an idea to see if its wheel bearing, drive up to speed , put car in neutral, and turn off car, if sound is still there, most likely wheel bearing
Old Jul 27, 2013 | 01:20 AM
seeyaass's Avatar
I don't think it's a wheel bearing cause it goes with the rpm of the car ya know. Ill try that though!
Old Aug 1, 2013 | 02:33 AM
seeyaass's Avatar
So I drove the car and turned it off and the noise doesn't go away. I'm pretty sure it isn't a wheel bearing though. I think it's something in the Trans
Old Aug 1, 2013 | 08:32 AM
user 72239's Avatar
do you have a LSD? could it be the differential?
Old Aug 1, 2013 | 09:45 AM
mongorat427's Avatar
Trans
Old Aug 1, 2013 | 12:49 PM
seeyaass's Avatar
I have the ZZP stage 1 trans with LSD. What could it be in the Trans? Roller bearing? It's more at higher speeds (I've 50mph)
Old Aug 3, 2013 | 12:18 AM
seeyaass's Avatar
Anyone have an idea of what it could be in the Trans? Clutch related maybe? When I push in the clutch while driving the noise stays, until the cars slows down a little then it slowly fades away
QuickSilver_SS
Sep 17, 2015 11:23 AM
yellowcobaltss05
Mar 28, 2007 07:27 PM
SSinPhilly
Dec 26, 2006 01:42 AM
RA071623
Jul 4, 2006 07:04 PM
