Will the dealership do speedometer calibrations?
Old Oct 23, 2009 | 11:33 PM
oldjoeclark's Avatar
I've got 18'' gunmetal sc wheels on my cobalt na. Its programmed for 17'' wheels. My speedometer is off. Will the dealership fix this or will they give you hell?
Old Oct 23, 2009 | 11:35 PM
kissrocker52's Avatar
i have the same issue
Old Oct 23, 2009 | 11:36 PM
D4u2s0t's Avatar
how much is it off by?
Old Oct 23, 2009 | 11:38 PM
about how much of a difference would it cause
like 10 mph.. its an automatic and it seems like it holds 1st gear longer than it should.. I'd like to keep the wheels on
Old Oct 23, 2009 | 11:40 PM
Joeyavhu's Avatar
Go here....
http://www.supermotors.net/calculators/index.php
Use the one on the bottom
It will tell you exactly how much you are off by... Its only gonna be like 1% or 2% lol Not worth the hassle and cost of a re-calibration, and most likely, your dealer will not be able to do it, seeing as they need rollers and a calibrated machine themselves.
it feels like that to me as well mine is an auto
D4u2s0t's Avatar
it should not be off by anything close to 10 mph by changing 1". how do u know it's off that much
Old Oct 23, 2009 | 11:41 PM
Joeyavhu's Avatar
Actually, I dont think I gave you the right site, lol...
Here you go
http://www.net-comber.com/tirecalc.html
Old Oct 23, 2009 | 11:43 PM
its only off by a few mph
Old Oct 23, 2009 | 11:47 PM
BLAZIN07SS's Avatar
I'm too JDM for you
no the dealer cant. the LE5 model did not come with optional 18 inch wheels so they don't have that calibration. hptuners can re-program that though
Old Oct 23, 2009 | 11:52 PM
This is the results i got... I swear its off by WAY WAY more than that ! Its crazy it will show i'm going 55 but i'm really going like 65. I"ve got speeding tickets to prove it.
Old Oct 24, 2009 | 12:00 AM
thats also what i got it must be right
Old Oct 24, 2009 | 12:10 AM
D4u2s0t's Avatar
a speedign ticket is not proof lol... how do you know it's off by 10 mph. are you basing that off of anything other than a speeding ticket?
Old Oct 24, 2009 | 12:12 AM
all it proves is that you were speeding that is even what the numbers show
Ok.. take the results.. Is that enough to Fu** up your transmission shift points? If you were me would you keep the 18's or just go back to the stock wheels?
Old Oct 24, 2009 | 12:13 AM
Acey's Avatar
I'm with d4. I remember looking it up cause I was gonna get SC wheels for my 2.4. 18's with 225/40 tires you're off by like 1 mph. 10 mph is HUGE. Something ain't right.
Old Oct 24, 2009 | 12:15 AM
D4u2s0t's Avatar
it's fine.... it's only a 4 speed auto so 1st gear is long. it's all in your head, because you think that your speedo is off, so now you're looking for "problems" that have happened because of it.
Old Oct 24, 2009 | 12:17 AM
should i be ok with the 18s that wont wrek anything right
Old Oct 24, 2009 | 12:20 AM
Acey's Avatar
Yes 18's will be fine... our cars pretty much the same as SS/SC's in that regard... same brakes, only slightly different suspension. Hell, there's morons that put 20" on these cars.
Old Oct 24, 2009 | 12:22 AM
cool and did you have any issues rubbing cause i have the plastic peice from my side skirts is bending out a bit and if i turn to fast i here it rube what should i do
Old Oct 24, 2009 | 12:26 AM
Acey's Avatar
How wide are your 18"? Stock is only 7" wide on the SC, like our stock wheels... if you have 8 or 8.5 inch wheels you might have rubbing.
Old Oct 24, 2009 | 12:44 AM
they were off a 2006 SS/SC and Mine is a 06 SS/NA
i just wanted to know if i was to bend the side skirt peice in the wheel well back agaist where it should be how should i do it
if it helps i will post a pic tomorrow
Last edited by kissrocker52; Oct 24, 2009 at 12:44 AM. Reason: Automerged Doublepost
Old Oct 24, 2009 | 01:23 AM
i have 215 45 18's and it did the following below..
https://www.cobaltss.net/forums/suspension-67/i-found-my-rubbing-problem-159938/
I had to hack saw that piece of plastic off
https://www.cobaltss.net/forums/showthread.php?t=159938
Last edited by oldjoeclark; Oct 24, 2009 at 01:23 AM. Reason: Automerged Doublepost
RaginChopsuey
Oct 27, 2015 01:27 PM
justinchinn
Oct 2, 2015 12:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
reybalt
Sep 27, 2015 07:57 PM
jcarroll53
Sep 24, 2015 07:43 PM
