window wont roll up?
so im sitting at work and the sky is slowly turning black so i decided to go roll my windows up since they were down in case it rained, well they all went up perfect except the passenger side window wont do anything? i took it home and put it in the garage then switched cars but does anyone have any idea what it may be? im coming here first instead of my dealership because theyre closed for the weekend and wont open until tuesday because of the holidayy
neither switch will make it work and if the motor went out wouldnt if have been stressing before this? cause it seemed to work fine and then all of a sudden it wont roll up? i checked the fuses but theres a single fuse for the windows and if that went out then all the windows wouldnt work correct?
Take your door panel off and tap the motor with a screw driver. Sometimes it will make them work again and you can roll up your window. I've done it a couple times on the dd. Now I just use the ac instead of putting down the windows.
