Wondering why those heated seats don't work?
Old Nov 19, 2013 | 11:17 PM
Spawne32's Avatar
So ive spent the last month diagnosing and trouble shooting my drivers side heated seat. In case you dont know, GM found a way to make heated seats a complex system that is wired into the BCM and controlled with 2 separate control modules underneath each of the seats. My passenger side heated seat system worked fine, you could measure 12+ volts at the connector going in from the switch to the control module, and 12+ volts being output by the lower cushion which is wired in line with the back cushion.
The drivers side however was only putting out 6.5v consistently on high or low power modes. Turns out the reason for this was damaged to the lower heating element, which contains not only resistors but a variable rheostat which the control module under the seat uses to regulate temperature. 6.5v is what is considered "low power mode" when the module detects that the pad has reached the desired temp. Any fault in this system and it doesnt work right. Strangely enough the switch does not thrown any indicator that there is a problem. (the switch will flash if the control module detects and under temp or overtemp condition apparently).
So i had to take the entire seat apart, and heres what I found.
the lower cushion is held on with 4 bolts underneath the seat rail, removing the lower cushion makes this job a whole lot easier without the need to disassemble the entire seat.
Here you can see where the element finally burned out from what i can only assume is a fault in the systems voltage regulation. The lower element is 60 dollars from GM, it is the more expensive of the two elements because it contains the entire wiring harness.
Here is a shot of the control module which is under the front of each seat.
And for future diagnosis problems, both wiring schematics...
Old Nov 22, 2013 | 12:33 AM
05g5's Avatar
Lol ill just let my car with no heated seats idle for 5 minutes before driiving in the winter, that with 5 min of driving down the road i got nice hot air blowing out on #4 setting.
Ill call it a day there
chefhhr
Oct 26, 2015 10:36 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
Tupp
Sep 29, 2015 11:07 PM
Sean Cummings
Sep 11, 2015 09:35 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
