jacking up the back??
Old Oct 19, 2006 | 07:40 PM
Eric304's Avatar
im painting my calipers and i was wondering where to put the jack to put the rear of the car up... i was thinking right under the trunk but not sure....
Old Oct 19, 2006 | 08:01 PM
k2kwj's Avatar
definatly not under the trunk... um you can jack up by the rear pinch welds but you need two jacks.... check your owners manual.
Old Oct 19, 2006 | 08:05 PM
campo165's Avatar
i jack it up by that steel framing that runs between the two tires...it looks madd weird...its got circular holes in it n stuff...you can also do it by that ball joint (on the frame!) it looks like a cylinder sort of?
Old Oct 19, 2006 | 08:09 PM
Boosted_SS's Avatar
WOW if you don't know how to jack a car up you should definately not be taking your brakes apart to paint them!
Old Oct 19, 2006 | 08:14 PM
k2kwj's Avatar
i agree
Old Oct 19, 2006 | 08:16 PM
rally's Avatar
Theres no rear ball joints on these cars, Solid rear end. Those cylinder things are your SHOCKS. I hope you havent been wrenching your car much.
And that bar is know as a ladder bar rear axle.
Old Oct 19, 2006 | 08:21 PM
mike25's Avatar
lube it up......dont want anything gettin stuck...
Old Oct 19, 2006 | 10:20 PM
Boosted_SS's Avatar
just take the lugnuts off and pull really hard on the wheel and you'll be good to go!!!
Old Oct 19, 2006 | 10:30 PM
JonyyB's Avatar
Site Founder
Tech Sections - The 2.0, 2.2, and 2.4 Tech sections of the forums are for anything relating to the performance aspect of these engines. Do not post anything that is not performance related in these three sections. https://www.cobaltss.net/rules.php
Please post in the correct section...moved
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
agentirons
Oct 16, 2015 02:11 AM
