South Mountain UT, AZ, NM, and CO
injectors
Old Feb 14, 2007 | 07:29 PM
T-Unit's Avatar
injectors
Wondering if i need to upgrade to 42# injectors when i install .y 2.8 pull, and will i need to get a smaller belt?
Old Feb 14, 2007 | 07:42 PM
RedSSBaltSC's Avatar
at least 42#ers and a stg 2 belt will be fine
Old Feb 14, 2007 | 07:49 PM
Imlikedrpepper's Avatar
there was a previous post about this saying its a bad idea
Old Feb 14, 2007 | 07:54 PM
Red2.4SS/SC's Avatar
a) you need a smaller belt b) if your at sea level a 2.8 and 42lb injectors will max out the injector duty cycle and c) if i were you , and you liked your car i wouldnt do ANY of this until you have a tune worked out or somewhere to go to get it tuned after the pulley and injector installation. Your cars gonna run like **** if you run a 2.8, 42lbers and no tune !!! if you dont live at sea level a 2.8 and 42's should be ok if your at sea level you need to go with 60lbers , siemens makes some there about 215 on svtperformancedotcom
Old Feb 14, 2007 | 08:11 PM
pclear9061's Avatar
would a smt-6 work with a 2.8 and 42.5's?
Old Feb 14, 2007 | 08:12 PM
what is that some sort of piggy back ecu
Old Feb 14, 2007 | 08:13 PM
Slobalt2.0's Avatar
Why dont you just have someone load a gm stage 2 tune in? I think I might know someone who can do it for you. But you will need to pay atleast 100 bucks for the credits.
Old Feb 14, 2007 | 08:22 PM
pclear9061's Avatar
1) i dont have the money to do that right now ....
2) im getting a custom HP Tuners tune for free
Old Feb 14, 2007 | 08:36 PM
then why do you want to piggy back your ecu
Old Feb 14, 2007 | 09:27 PM
pclear9061's Avatar
i already have the smt-6 hooked up on the car with my 3" pulley ... when i bought it awhile ago i was told it was tuned for a 2.8 and i think injectors too but i was told it would run fine with my 3" ... thats why im assumeing that it would work but im not completely sure ...
Old Feb 14, 2007 | 09:34 PM
JohnfromVA's Avatar
ive always said if you are going smaller than the stage 2 pulley it is a good idea to go with the 60's
Old Feb 14, 2007 | 09:40 PM
Asphalt Assault's Avatar
1000 ft and above sea level with 42's work with 2.79" with a tune.
You just need to know how to set it up.
Old Feb 15, 2007 | 09:03 AM
T-Unit's Avatar
I took my 06 ss/sc in to the dealer and i talked with a mechanic about running a 2.8 pully on stock injectors he said they can handle it.. Also do the ss/sc come with 42# injectors no one can give me a straigh answer on whats the stock #..
Old Feb 15, 2007 | 09:07 AM
Slobalt2.0's Avatar
Its 36# for the stock injectors. Stage 2 comes with new injectors which are 42#...... 36# injectors cannot handle a 2.8 and I garuntee you that. 42# injectors have a hard time. If you have Hptuners you can see what your Injector duty cycle is and it would be extremly high.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
