South Mountain UT, AZ, NM, and CO
Need help installing Polly Mounts
Old Dec 17, 2007 | 04:28 PM
The Punisher's Avatar
I was just wondering if anyone here in Colorado has the necessary tools to install the polly mounts on my 07...Thanks
Old Dec 17, 2007 | 04:29 PM
TurboTechRacing's Avatar
Screw driver, basic socket set, and a bench vise should be everything you need
Old Dec 17, 2007 | 04:32 PM
D4u2s0t's Avatar
i've helped some local members do their mounts, if you were close i would show you how. it's really not that hard if you havea jack, jackstands, and basic handtools you can do it no problem. do you have tools? if you have tools, and still need help, pm me your quesitons and i'll help you out.
Old Dec 17, 2007 | 04:41 PM
hmm I was under the impression u need to have some type of press?> or special tools..
Old Feb 15, 2008 | 05:28 AM
domin8_gt's Avatar
littless on the RME forum can help you if you don't already have them installed.
www.rockymountainecotec.net
Old Feb 15, 2008 | 10:09 PM
whodis's Avatar
he should know abt little ss, he bought his stage 3 kit.
Old Feb 15, 2008 | 10:12 PM
Super_SS's Avatar
i suggest u do the back one first..just take the old motor mount out(whole assembly)and push out the stock rubber and insert the aftermarket once's...u might have to shave one side of the poly mount to make it fit into hole
Old Feb 15, 2008 | 10:16 PM
Red2.4SS's Avatar
Its easy just did it on my buddies car last night.
18mm socket, 15mm socket, ratchet, plastic mallet, large flathead screwdriver, jack and two jackstands is all I used. Maybe some grease or oil for the mount install.
Old Feb 15, 2008 | 10:18 PM
Super_SS's Avatar
cooking oil is good as well..works like a charm
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Oct 1, 2015 10:00 PM
n20saturn
Sep 30, 2015 12:26 AM
