- MRZ Performance - Lightweight and Underdrive Pulley group buy for Ecotec's
#103
We do not plan on making an overdriven pulley since there are already many options for those who wants to reduce the supercharger pulley size to get more boost. We can always do it as a custom sized pulleyif you wish to go that way...
#104
The bolt is a torque-to-yield bolt, best not to reuse the original one. Factory service manual states to replace the bolt.
With the MRZ pulley (because it is aluminum) you will not torque the bolt to yield so you can reuse it again.
.....and you would be defeating the primary purpose -- more power -- of a lightweight pulley by overdriving the alternator and AC compressor just to speed up the supercharger.
#106
2.2 and 2.4 owners who get the UDP will need the smaller belt ACDelco PN 5K390 -- MRZ can supply those if you want.
Note on the belt tensioner: The only attach point is a 3/8 inch square hole -- not every belt tensioner tool will work. You can use a jack and a bar to move the tensioner to get the belt on and off.
#107
Can anyone vouch for the performance increase with the lightweight pulley on a 2.0 SS/SC? Just faster revs or a little more power?
#109
Thanks for joining the group buy we need 2 more people!
We feel it is very easy already to adjust boost level as wanted with SC pulleys, the belt size might also be a problem with the oversized pulley...
Regarding the competition pulleys... We consider a crank pulley should not be a 2 pieces assembly for perfect balancing and strenght. We did look a this possibility in the past for cost reasons but we realized the pulley need to be made from a full chuck of billet aluminum for a perfect balancing and integrity. This cost more to produce for us, but this is far more accurate since this is a single piece and not an assembly.
I was just curious if MRZ was going to make an overdrive pulley similar to another supporting vendor to potentially attract those customers with their slightly lighter weight and better priced product...
Last edited by MRZ - RedGTZ; 11-11-2008 at 08:34 PM. Reason: Automerged Doublepost
#110
Thanks for the info, I am considering joining this GP.
I do need to know however what if "felt" with this mod... Is there actual increase in power, or just some faster revs / better response..?
#111
Are you any closer to having these ready? I would like to jump in on the group buy, but I really was interested in getting both pulleys at the same time. That way I can maybe save some money on the shipping and the install. So any updates?
#114
I can't answer for the original size pulley, but the UDP on my 2.4 feels like it has quicker throttle response at low speeds.
#115
We only need a few more people for this group buy... this is a great opportunity to save on the UDP or Lightweight pulleys
BTW the alternator lightweight pulleys will be available in approx. 2 weeks from now.
#116
can we expect a group buy on alternator pulleys when they are available you guys rock.
bump for more to join the group buy...
#121
Once the alt. pulley will be ready, we can do a group buy if we get enough interest...
you can wait for the end of group buy before sending payment, thanks!
Last edited by MRZ - RedGTZ; 11-16-2008 at 10:06 PM. Reason: Automerged Doublepost
