B&G Spring Problem..
Hey guys, on tuesday i installed b&g springs on my sedan and i have been getting a vibration from the front of the car. Ive checked a few times and made sure everything is tight and installed correctly. I took it to the shop and they said the axle is binding because its too low and that is whats causing the car to vibrate, mainly while picking up speed. My question for you guys is, has anyone ever ran into this problem, or does anyone know what i can do to fix it? I am going to install the stock front springs and see if the vibration still occurs.
Thanks in advance.
Thanks in advance.
Vibrations can be caused by so many things. Maybe the axles or binding, but you'd probably hear or feel it. It's pretty distinct. Did you knock a wheel weight off by accident? Alignment could also help.
I have not personally seen lowering springs that will bind axles.
Well about the wheel weight, they did say my tires needed to be balanced so they did that and i thought thats what the vibration was, but it wasnt. At the shop they had it up on the lift and a guy was inside and pushed the gas while a guy was under it inspecting it, so i think they were pretty sure its the axle.
Thats weird though, because I know a few people with cobalts lowered on B&Gs and they dont have this problem
Someone said rack spacers will help solve the problem, is that true?
Rotated mounts will help you out. It should rotate the motor a little to take the binding affect away. I have progress springs and my axles aren't binding so I don't know whats up with yours.
Guys I need suggestions on this if you know anything that will help me out let me know.
when you jacked the car up, did you put something under the front calipers to keep the weight off your axles? because if you let them down without something under them, the entire weight of the assembly is resting on the axle, and I've seen the axle bend a decent amount, perhaps you've bent it enough and it's not straight now? idk, jsut my two cents. also if it's bent that would cause it to be a little short as well.
from what i noticed it vibrates because the car is lowered so much that axles arent parallel and the hubs are up higher then trans is so the axles has to rotate in a oval fashion. with the auto cars your cant use rotated mounts
ya man i took my h&r's off today. took the fronts off and left the rear in and it drove perfect again. im over peicing stuff together to make it work so i took them off fully and put the stocks back on and i have no issues so im happy. now i just want my money back on the worthless springs
by the way i saw your car at the pavs last night
Yeah i have the same car as him except its a 2.4 haha and nah i wasnt showing my car i was just walking around with my girl. Next time i go ill for sure see if youre goin park next to you
DANRICKARD
Oct 1, 2015 12:08 AM
