bad Rear control arm bushing what are the symptoms
Old Oct 17, 2011 | 05:01 PM
outtamymind's Avatar
try your upper strut mounts, they can go bad over time and cause vibrations as well
Old Oct 18, 2011 | 08:18 AM
Shogokuma's Avatar
i bought these struts from a junk yard they are 2009 with 44k on them do you think they would be bad?
Old Oct 18, 2011 | 12:11 PM
the struts maybe not but the strut mounts could be cracked or have gone bad.
Old Oct 18, 2011 | 04:37 PM
Shogokuma's Avatar
i will check it out.
Old Oct 18, 2011 | 04:51 PM
68nova200's Avatar
do you have rack spacers? Just throwing that out there as an idea. My parents hhr has some vibes and it is lowered with no rack spacers.
Old Oct 18, 2011 | 06:22 PM
Shogokuma's Avatar
rack spacers are so cheap i might as well try it
Old Oct 18, 2011 | 06:27 PM
LS6Rally's Avatar
have you thought about switching the springs back and seeing what happens?
Old Oct 19, 2011 | 09:30 AM
Shogokuma's Avatar
i think switching to stock heigh will solve my problem but i like the look alot better when its dropped. the other day i drove with a full car of large people and the vibration was strong
Old Nov 6, 2011 | 07:54 PM
Shogokuma's Avatar
how do i see if my strutmounts are bad?
i turned my wheels and looked at the mounts and the nut was moving up and down
Old Nov 7, 2011 | 12:42 PM
ItalianJoe1's Avatar
What nut was moving up and down?
The only way to check strut mounts is to turn the wheels with the front end off the ground and feel for any roughness or anything. Or pull the struts and look at them, turn the mount by hand and feel it for play.
Old Nov 7, 2011 | 12:46 PM
  #36
Shogokuma's Avatar
the only nut you see n top of the strut mount when you have the hood open, i did that parked at a gas station... moved differently than the other side which had almost no play
Old Nov 7, 2011 | 12:53 PM
  #37
Yeah that top nut really shouldn't move.
Did it get tightened down properly when the springs were installed?
Old Nov 7, 2011 | 01:18 PM
  #38
Shogokuma's Avatar
yes its been done with an impact wrench (electric) im thinking the rubber part is bad, i hear the bearing is bad also once the rubber is bad can someone confirm that?
Oct 13, 2015 09:32 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Coballin13
Sep 25, 2015 08:43 AM
