Best Lower control arm bushing?
Old Jan 5, 2010 | 11:59 PM
qwikredline's Avatar
Originally Posted by rallyracer
I have an 07 ss/sc but have no idea how to tell which controllers I have... Is it something easy to check?
Switching to the Brembo's keeps sounding more and more like a pain in the ass ...thats it, Im driving to Powell's shop...I'll film the how to video while he installs
Happy to see you!!
just look at the abs controller: if it says Bosch on it, thats one thing. If it says Delphi, thats another. I will try and find you piktars...
and serially I can put together a kit for you by say Tom at CED and do a how to for you. He will do the oem parts, I can put together the special non OEM Stuff you have to do....
or contact OTTP for a BBK full floating kit using your stock Caliper thats a 312 mm rotor, not bad... here it is....
Old Jan 6, 2010 | 12:15 AM
rallyracer's Avatar
/\ OMG those are sexy!!!
Does the BBK (koni racing brakes) setup fit inside a stock SS/SC wheel?
Originally Posted by qwikredline
Happy to see you!!
Yeah if you could put together a parts list that would be awesome... then I can look into how much its would to cost.
Or do you have an est cost on who much switching over to Brembo's could run?
Old Jan 6, 2010 | 02:02 AM
Maven's Avatar
Dose the BBK (koni racing brakes) setup fit inside a stock SS/SC wheel?
Yes the Koni BBK fits in stock wheels, it even fits in 17's, its what I run:
Switching to Brembos is cake, it seems like youre stuck on the TC knuckles, which is actually the most involved part and not truly needed. Brembo kit will probably run you $1000 minimum including new brake hoses and fluid.
Old Jan 6, 2010 | 05:40 AM
rallyracer's Avatar
$1000+ for Brembo vs $850+ for BBK...hummm
I'm not stuck on TC knuckles...I just know I need to either get the competition / G6 or TC ones depending on which way I go.
So with running the BBK up front what do you about the back? ...Change anything?
Old Jan 6, 2010 | 07:58 AM
phatnackySS's Avatar
... how much do replacement rotors cost ? im more of a weekend worrier with my car,so it sees a lot of DD duty, wouldn't want to break the bank on routine maintenance.
Old Jan 6, 2010 | 08:59 AM
the PFC rotors are around $200 complete with hardware, the Coleman TC around 300...hats are a one time cost.
I have no clue how long they last on the street I am guessing forever.
It is driver dependent I suppose, I got 125,000 miles and never replaced pads on my 06 GMC 2500 brakes towing trailers before I sold it. Good sized quality rotors do last a long long time...
I also dont know what the effects of long term corrosion salt/snow does to the floating rotor, I would guess regular cleaning etc would take care of them. Maven and Area 47 are the true long term testers of the BBK set up thats what they run. I have a Brembo TC floating rotor set up but it dont run in the winter...
Old Jan 6, 2010 | 10:04 PM
rallyracer's Avatar
Mine will have to be able to run through winter...
Old Jan 6, 2010 | 10:19 PM
Maven's Avatar
you can run them through winter no problem, but you should really disassemble and clean them in the spring.
Old Mar 4, 2013 | 10:59 PM
07cobaltss LSJ's Avatar
I'm lookin to getting a new Suspension for my 07 lsj cobalt. I would
Like to upgrade but reading up on some things now I kinda think they might be my contour arms or bushings. I don't know to much about Suspension so if you his could give
Me some pointers it would be much appreasted. Thanks
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Coballin13
Sep 25, 2015 08:43 AM
