Blown strut question
Old Apr 8, 2010 | 12:15 PM
brickloaf's Avatar
Basically my passanger side front strut is completly fucked and I want to replace both the front ones...my question is can I just replace the 2 front struts with TC struts and be good to go or do I need to replace the shocks as well even if my stickers are good...it's a 07 LT with 55k if that helps any
Thanks
Old Apr 8, 2010 | 01:07 PM
northvibe's Avatar
..you could do just the front..but meh if you got the spare cash just get all 4 and be done with it. Otherwise you'll have a saggy ass rear end that handles like crap and a fresh new end that is good. imo do it all at the same time. Otherwise missmatched parts can suck.
Old Apr 8, 2010 | 01:54 PM
brickloaf's Avatar
True but I don't have the spare $$ and tc struts aren't that much more expensive than stock replacements...will tc struts lower my car at all, I don't expect a huge drop but maybe a half inch lower or something..
Also can you replace just struts and not shocks and be good to go??
Old Apr 8, 2010 | 02:00 PM
jlong3382's Avatar
Ya..........if your shocks are still good. I don't see how replacing the front struts with an OE equivilent would be a bad thing. However if you upgrade, upgrade the struts and the shocks. If you don't you handleing will be affected.
The springs are what affects your ride height. Not the Struts.
Old Apr 8, 2010 | 02:06 PM
northvibe's Avatar
well the tc struts are more "performance" minded over the stock lt ones. So it may lower the front a little bit. But ya if you keep the same springs you shouldnt notice too much. Do as you wish, but did you check Create engine depot for all the struts/shocks? maybe cheaper than if you asked local for prices.
Old Apr 8, 2010 | 03:37 PM
brickloaf's Avatar
This is what I was looking at would I need 2 of these to change out all 4??
http://www.crateenginedepot.com/stor...roduct_ID=2433
Old Apr 8, 2010 | 03:41 PM
northvibe's Avatar
no that is the kit that comes with everything (2 front struts and 2 rear shocks).
Included in Package:
1 RH Strut
1 LH Strut
2 Rear Shocks
Old Apr 8, 2010 | 03:47 PM
brickloaf's Avatar
Damn idk anything about suspensions...is there no struts on the rear??
Old Apr 8, 2010 | 03:59 PM
northvibe's Avatar
nope, those are shocks in the rear.
Stiner's Avatar
shocks in the rear not struts
Old Apr 8, 2010 | 04:28 PM
brickloaf's Avatar
Alright thanks!
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
Tupp
Sep 30, 2015 08:18 PM
ThoR294
Sep 28, 2015 05:31 PM
