Bump stops
Old Mar 29, 2007 | 09:45 PM
Blankobalt06's Avatar
Bump stops
How important do you think it is to cut the bump stops? I'm going to have a garage install the springs I have (sportlines) and don't think they will cut the bump stops. Can I cut them afterward? Anyone chime in please. Thanks, Jason
Old Mar 29, 2007 | 09:46 PM
XM15's Avatar
Thats what the manufacturers recommend, so I would do it if I were you. Look in the how-to section; there is one that shows how to do the rear springs.
I found it:https://www.cobaltss.net/forums/how-guide-43/rear-spring-install-bumpstop-cut-25851/
Hope that helps!
Old Mar 29, 2007 | 09:56 PM
Yeah...I saw that and that's why I was wondering. Can they be cut after the springs are on?
Old Mar 29, 2007 | 09:59 PM
Halfcent's Avatar
I'm old school
First. please try a search. There are TONS of threads about this.
Second, your springs should include instructions that specifically tell you how much, if any, stop to cut off. The Pro-Kit for instance says NOT to cut the stops.
They have to be cut while the springs are off. You can not do it afterwards.
Old Mar 29, 2007 | 10:11 PM
I apologize. I wanted opinions more than anything. I read the how to. I head some people talk about putting springs on but nothing about cutting the bump stops. The people that did cut them did it at different amounts. Should I just the bump stops out? Is that bad? If I put the BC2 kit on with 18's are the ground effects going to bottom out a lot. I guess I'm just a little confused. I could be searching forever to answer these questions. I couldn't find the detail I was looking for in any of the searching I did do. So any help answering these questions will be appreciated. Thanks in advance.
Old Mar 29, 2007 | 10:17 PM
Halfcent's Avatar
I'm old school
Absolutely do NOT just remove the stops. 18" wheels mean nothing, its the tire size that's important. The BC2 kit has a low front end. You can expect to ground out on curbs no matter what suspension you have.
Old Mar 29, 2007 | 10:19 PM
XM15's Avatar
I guess if the springs didn't come with instructions concerning the bumpstops, my advice would be to call the company.
Old Mar 29, 2007 | 10:20 PM
Thanks guys
Old Mar 30, 2007 | 08:20 AM
SSKevinSC's Avatar
NO NO NO It is impossible to cut them after You would have to take all the springs off again.
Old Mar 30, 2007 | 03:13 PM
WhiteSSBalt's Avatar
Not a Sebring
I trimmed mine to Eibach's reccomend spec's, and haven't had a problem thusfar.
Old Mar 31, 2007 | 12:12 AM
Florida 76's Avatar
CUT THEM
bigdeertz
Nov 17, 2016 09:41 AM
biniecki
Oct 25, 2015 02:23 PM
Dirtybutwhole
Sep 26, 2015 06:53 PM
