Camber Adjustments
Old Jul 28, 2010 | 04:33 PM
Joel88's Avatar
Question Camber Adjustments
I was wondering what to have my camber set at. I am novice to this type of thing, i've heard other members say -1 degree. My tires are wearing in the inside of tire so i need to adjust it.
Also, I bought an Eibach camber kit for the fronts. Has anyone ever used this before? Do i leave the camber kit bolts in or do i take it back out after it adjusts?
Its on a 2009 Cobalt LS with 17" aftermarket wheels. Any help would be great
Old Jul 28, 2010 | 04:40 PM
Wangspeed's Avatar
Camber doesn't wear your tires as much as toe. Make sure toe is set properly. Zero toe for less wear.
Old Jul 28, 2010 | 04:41 PM
ls1fbody's Avatar
Haz l33t wheelz.
This.
Also, if you install camber bolts, but a single one in the top. If you are able to adjust the camber to your desired settings without them, then don't bother.
Old Jul 28, 2010 | 09:26 PM
Joel88's Avatar
I checked the toe today and it is at Zero toe. I am waiting for my UPS to get here with my Camber checking tool (lack of better term) it will hopefully show some results.
SmitBag
Sep 7, 2016 08:05 AM
toysareforboys
Nov 17, 2015 05:22 AM
justinchinn
Oct 2, 2015 12:18 PM
The Rookie24
Sep 20, 2015 04:33 PM
brett.higgins3
Sep 14, 2015 01:48 PM
