Camber issue with springs
I don't remember the lat time I started a thread, and I know there are tons of Pedders threads.
Sooooo, just a few answers from ppl who have Pedders installed on TC's...and we can be done.
Do they throw the car off camber?
They are performance springs, so adding springs and spacers do improve and don't have any issues......camber wise?
Thanks
Thanks
Thanks
Thanks
They do if you lower them more than 2.5" or so.
Peddars offer a moderate drop, so camber changes will be minimal. I never got an alignment after installing my Progress springs and I haven't noticed any abnormal tire wear.
figured I would explain. Put camber to one side for the moment.
As you lower the car with springs, the trim height changes the wheel travels up and as it does so it pulls the tie rods in.
As the car has trailing tie rods (behind the axle centerline ) the wheels go to toe out. If you raise the rack with spacers of the correct thickness, and you assume your toe was perfect before you put the springs in (say zero for arguments sake) then change to Pedders, insert rack spacer, and alignment will be exactly the same, all things being equal.....
