Does anyone have this issue
ok idk if anyone else had this problem so im just posting it up here to get some advice on what i should do...
i lowerd my car on the ksport coilovers on my ss/sc now in the front how we have the plastic flap under the car do we need that there couse im soooo temptd to ripp that outa there...my boi on the forum that also lives across the street from me said that its some type of heat remover kinda deal...but idk what to do has anyone removed theres
also on the ksports they have the adj coil that sits on top of the spring but the stance of my bank end doesnt lower any advice on how to get it lower? im thinking remove it altogether
thanks in advance
thanks in advance
thanks tho
guess i have another day ahead of me 2 ripp off my bumper again
i went half way inbetween keepiong it and removing it, i cut 1" of the bottom of it, problem solved. motor ran the same temps, no change there. besides, the last thing you need it to do is hook a rock and kick it into the a/c condensor/heat exchanger/rad
ok now my other prob how do i lower my back end on the ksports couse the way how it sites now looks stock i prob droped it about a half an inch but the way the back springs sits is
the bottome spring cuplet(whatever you wanna call it)
the ksport spring
the ksport coil
then the top cutlet that goes into the coilover then into that lil nub that hangs down
is that the correct line up? i followd it on someones how to an he just showd a pic of it an didnt get into detail but i think if i left out that lil coil top i will see a better difference then if i would with it there
the ksport spring
the ksport coil
