G6 GXP Front Calipers
Old Nov 29, 2008 | 08:49 PM
Maven's Avatar
Plan on having all 4 hubs and rotors drilled out to the new bolt pattern. Then for extra piece of mind you should really have some backup washers made and tack welded onto the back of the hub for where your new studs will go through. This would be a good idea because where the stock sutds go through the hubs they are thicker than the rest of the hub.
You can thank qwikredline for taking some pics and drawing out some bolt patterns for that last bit of info.
Cobalt hub with 5x114.3(4.5") PCD layed out
View of hub backside, notice reinforcing area around studs
Here we have some sexy PFC Direct Drive, Floating GAC spec rotor drilled with the GA hubd and stud pattern as well as the 110 pattern(unused holes are the larger pattern, notice the center bore is too large for hub, this is why you need to drill out your rotors to fit on GrandAm hubs)
Old Feb 14, 2010 | 01:39 AM
YelloEye's Avatar
Bringing it back from the dead, any chance Powell RaceShop or any other distributor would be willing to produce a run of re-drilled hubs? I'm sure we could stir up enough interest on CSS alone to make it worth while.
Old Feb 14, 2010 | 01:44 AM
ls1fbody's Avatar
Haz l33t wheelz.
they won't re-drill them because of the lack of reinforcement there.
Old Feb 14, 2010 | 01:49 AM
rallyracer's Avatar
G6 GXP Knuckle is the same as GMPP Cobalt competition knuckle right?
Old Feb 14, 2010 | 01:51 AM
ls1fbody's Avatar
Haz l33t wheelz.
i believe so.
I saw a picture somewhere of the LSJ, G6, LNF knuckles all lined up. the G6GXP uses same caliper as SS/SC according to maven here in this thread.
Old Feb 14, 2010 | 03:26 AM
Boosted_Cobalt09's Avatar
i do have a a pic of all 3 knuckles lined up together. the g6 gxp is large then the stock sstc and lsj knuckles
Old Feb 14, 2010 | 03:35 AM
rallyracer's Avatar
well John said they used the G6 knuckles on the Race Cobalts...I was just wondering the they were the same as the GM competition knuckles.
Old Feb 14, 2010 | 08:56 AM
qwikredline's Avatar
yes but.....need to be re-drilled
Old Dec 13, 2010 | 01:08 AM
Ting-ting's Avatar
ok so yall are confusing so your saying i can take off my stock hubs drill out the 5x114 pattern...and as far as rotors can i just redrill that as well
and thats it??and run my 17x9.5 sbc rpf1
Old Dec 17, 2010 | 04:26 AM
YelloEye's Avatar
Yes...however due to the lack of reinforcement of the hub in that location it wouldn't exactly be safe.
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
n20saturn
Sep 30, 2015 12:26 AM
grampss
Sep 27, 2015 08:51 PM
