G6 GXP Front Calipers
Plan on having all 4 hubs and rotors drilled out to the new bolt pattern. Then for extra piece of mind you should really have some backup washers made and tack welded onto the back of the hub for where your new studs will go through. This would be a good idea because where the stock sutds go through the hubs they are thicker than the rest of the hub.
You can thank qwikredline for taking some pics and drawing out some bolt patterns for that last bit of info.
Cobalt hub with 5x114.3(4.5") PCD layed out
View of hub backside, notice reinforcing area around studs
Here we have some sexy PFC Direct Drive, Floating GAC spec rotor drilled with the GA hubd and stud pattern as well as the 110 pattern(unused holes are the larger pattern, notice the center bore is too large for hub, this is why you need to drill out your rotors to fit on GrandAm hubs)
Bringing it back from the dead, any chance Powell RaceShop or any other distributor would be willing to produce a run of re-drilled hubs? I'm sure we could stir up enough interest on CSS alone to make it worth while.
ok so yall are confusing so your saying i can take off my stock hubs drill out the 5x114 pattern...and as far as rotors can i just redrill that as well
and thats it??and run my 17x9.5 sbc rpf1
DANRICKARD
Oct 1, 2015 12:08 AM
n20saturn
Sep 30, 2015 12:26 AM
