Got my pedders installed. pretty sure i dicked up the rear ones tho.
Old Mar 11, 2011 | 01:43 PM
Dart_SI's Avatar
Originally Posted by CordiaDOHC
Good to hear! Now get some pics up!
not edited
Old Mar 11, 2011 | 01:48 PM
1LowLS's Avatar
Ive had them installed both ways and didnt know any difference.If there a progressive rate spring I wouldnt think it would matter but im not sure
Those look good!
Old Mar 11, 2011 | 01:56 PM
cubaniche's Avatar
x3 on shaving the bump stops a bit. I had to shave mine slightly to make them pop in and fit in place.
Old Mar 11, 2011 | 02:06 PM
1LowLS's Avatar
I had to cut mine in half.Im not on pedders though so Im sure it varys
Old Jun 25, 2011 | 03:21 PM
07BoostedG5's Avatar
Just came on to find this thread. Those rear bump stops were a pain in the ass, I just finished them now Im doing the front, but anyways, I thought the weight of the car would press the rubber bump stop in, no way! ended up taking them apart again, put a little wd40 and tapped the edges with a ball pin hammer, and it slide right in....alright back outside now to do the fronts man I hate doing the fronts, I have done springs on this car too many times, base to sportlines then back to base, then to fe5s and then the fe5 struts/shocks with fe5 springs and now to pedders, hopefully this is the last time!!!
Old Jun 25, 2011 | 03:27 PM
ronn's Avatar
Did you insert the end caps and bump stops on the springs BEFORE inserting them?
Left spring YES....Right spring NO.
Old Aug 1, 2011 | 02:02 PM
RoadconeTuning's Avatar
are you guys using a spring compressor at all? sounds like you're trying to just set the springs in... only car i know of you can do that on is a mustang and thats because the lowering springs will literally fall out if you pull down on the axle lol
Old Aug 1, 2011 | 08:40 PM
Powell Race Parts's Avatar
Blazin07SS in Miami suggested a heat gun for the rear lower isolators, thats what I do now, and it works like a charm. Before that I used WD 40 lol
The latest Pedders CED are selling appear to be a little larger on the pigtail end compared to before. I get our Pedders from CED great prices and they have inventory.
Old Aug 1, 2011 | 08:51 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
You don't need a spring compressor on the rears of our car.
Oct 13, 2015 09:32 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
DocSvensk
Sep 27, 2015 02:24 PM
