Help, Car pulls left when I let off the gas
Old May 24, 2012 | 08:07 PM
beast10007's Avatar
So when I let off the gas my car jerks to the left and my wheel moves about 20% to the left if I hit boost the wheel gets straight and the car jerks also its really hard to keep the car straight under high boost, I dont think I hit anything and I took it to bell tire and they said nothing was wrong...
Old May 24, 2012 | 08:09 PM
LS6Rally's Avatar
im not too sure but my best guess might be a collapsed brake hose. does the car brake straight or does it pull the same while stopping?
Old May 24, 2012 | 08:15 PM
beast10007's Avatar
I am sure it breaks straight I will check tomorrow when I go to work
Old May 24, 2012 | 08:16 PM
LS6Rally's Avatar
if it brakes straight i would think that it is a collapsed hose.
The hose would allow fluid to the caliper under braking pressure, but when you release the brake, the fluid doesn't have enough force to get back through the hose, causing you pads to be constantly dragging on the rotor.
Old May 24, 2012 | 08:20 PM
beast10007's Avatar
ok thanks a lot I am going to look at it tomorrow when I get out of work, I did notice that my rotors are hit! and wore really fast
Old May 24, 2012 | 09:11 PM
YelloEye's Avatar
Does it pull when it's in neutral? Braking? If you pull up on the ebrake does it straighten out?
Old May 24, 2012 | 09:21 PM
beast10007's Avatar
I dont know I have not drove with the ebreak up i will try tomorrow, do you think new breaks can help?
Old May 25, 2012 | 10:46 AM
beast10007's Avatar
up date
ok so I went for a little drive and the car drives great when I give it gas but when I let off the wheel jerks to the left when I hit the break the wheel really turns hard to the left almost 45 degrees by the time I hit a full stop I can make my car switch lanes by just letting off the gas, when I am in neutral the car pulls to the left and the car is turning left, I feel like this is all coming from my right wheel......
Old May 25, 2012 | 09:00 PM
Nevacme's Avatar
It might be tha caliper cuz its seized
Old May 25, 2012 | 09:02 PM
LS6Rally's Avatar
the only way that the right side of th car is causing the car to pull left is if the right front or rear caliper is not working at all.
Old May 26, 2012 | 10:08 PM
beast10007's Avatar
thanks guys I am going to be taking a look at it tomorrow I hope its just the break line because if it is then I am going to get zzp ss lines
Old May 26, 2012 | 10:46 PM
2010Cobalt's Avatar
Your driver side caliper is junk. It is clearly stuck closed. Unless something is severely bent and making your car pull left. But it deff sounds like your caliper is junk or your brake line is broke.
Does your brake pedal feel light and drop to the floor?
Does it smell likes brakes after driving?
How many miles on the caliper???
Old May 27, 2012 | 12:14 PM
beast10007's Avatar
no breaks seem fine and I never smell breaks I did notice it was sticking, I have 44,XXX on them mostly highway but I do auto X my car every other weekend....
would this be covered by my dealership?
Old May 27, 2012 | 12:45 PM
2010Cobalt's Avatar
If they know your racing prob not lol. Idk you will have to have someone look at it, can't tell through words. Sorry.
Old May 27, 2012 | 01:15 PM
2010Cobalt's Avatar
Mabe your alignment is really off from racing? Your alignment is set up to go strait and you just where racing in circles lol. That prob has a lot to due with it, mabe you broke some suspension upfront.
Your car sagging on driver side?
Does anything look bent or broke driver side?
Does the car dip down when braking?
Old May 27, 2012 | 01:39 PM
beast10007's Avatar
had the alignment checked 2 times and I have had it on my lift like 4 times and everything looks good I just blend my lines and I am going to c if that helps
Old May 30, 2012 | 06:39 AM
2010Cobalt's Avatar
Figure out what was going on with the car?
Old May 30, 2012 | 06:45 PM
beast10007's Avatar
I looked at it and the caliper is seized i am going to hold out tell the end of the month to buy it cuz I just bought a new tv...
Turbo Johnny
Feb 21, 2019 09:41 AM
How to Guide
57
Oct 15, 2015 11:56 AM
twilson380
Sep 14, 2015 10:52 AM
Highgross89
20
Sep 11, 2015 03:24 PM
soundjunky
Sep 3, 2015 01:18 PM
