How long will factory struts hold up?
I'm looking at buying some Eibach Sportlines for my 2.2. But I don't know how long the struts will hold up before replacing them with the Koni aftermarket's. Anyone have any idea, or experienced any problems with the springs and/or struts?
If I'm worried about struts for my 2.2, should I go with the Pro kit instead?
Any info/ideas/suggestions would be appreciated...
Please try a search before making a new thread. There are many threads already on this topic.
We have yet to see reports of people having to replace their struts due to spring changes. I have Prokits and they so far have been perfectly fine after more then a year. You can replace your struts with FE5's rather then Konis when the time comes.
I've had my car on Sprints for about 30K...
if you've got the money honestly just upgrade because the ride quality will be much improved a long with better handling.
i would say my struts are wearing down but they're still driveable and not noticeably bouncier...but still I would and plan to upgrade.
Last edited by ReggaeRampage; May 22, 2007 at 09:13 PM. Reason: Automerged Doublepost
im dropped on ssc springs and have rear koni's. i will be upgrading my front struts with koni's once they blow as you need to drain the oil anyway to install the insert. might as well weight till there blown anyay as ya got to cut it open
importkiller
Sep 30, 2015 07:18 PM
