Ingalls bad??
Sorry to thread jack, but what is the proper way to install the Ingalls? Is there a certain ft/lbs you tighten all the bolts so it's not overly tight and bend? I'm in the market for one and am just curious.
Some believe it is adjusting the "strut" improper, adjusting it while it is on the car is a big "no no". However, some have had it at the stock setting, no adjustments (at least stated this way) and it still bent.
Straight Information nothing more nothing less:
Ingalls first generation mounts had issues with bending the brackets.
The new versions no longer have this issue due to heavier brackets and stronger frame.
The vast majority of all Ingalls have never had problems with many users having 3 yrs on them.
TTR has great solid engine mounts that hold up and do the job.
Never seen complaints from there product.
Pros vs Cons
Ingalls
Pro:
Ingalls you can pull off the car in 2 minutes and back on in 2 minutes making it easy to take to dealership for warranty work
Stiffnes can be adjusted at any time so set to the demands you need.
Con:
Not as strong as solid mounts.
TTR Solid mount:
Pro:
Keeps engine from moving better than ingalls.
Looks less suspicous in engine bay.
Con:
Vibrates the car like an old muscle car (might be a pro if thats your thing)
Is not adjustable
There so can we stop arguing?
Both are good products.
Pros vs Cons
Ingalls
Pro:
Con:
TTR Solid mount:
Pro:
Con:
Is not adjustable
It is not the "brackets to the engine or frame bolts/nuts torque spec"
When the brackets are lined up right , and the strut is adjusted correctly ...the force goes straight back towards the firewall so the brackets have no side pressure on them at all, that is where the strength is .
Well this ramble prolly won't make sense to most , but hopefully it helps some.
You need a website update
https://www.cobaltss.net/forums/show...8&postcount=14
https://www.cobaltss.net/forums/show...+bent+brackets
A quick 2 minute search pulled these up and many more, yet we are making this up? I think someone is calling the kettle black when they say "vendor bashing"
Bottom line what we stated is the truth from first hand experience from OTHERS
So "BLAZIN07SS" and "qwikredline" being you two are so "knowledgeable" and like to voice your opinions, you both know this information YET failed to admit it, instead you would like to bash us for being TRUTHFULL. Ingalls has been known to bend the brackets, we TTR have never had any structural issues. That is exactly what we stated and it is exactly the truth, proven above.
/thread
/thread
Just my 2 cents but you guys have nearly nothing for 2008-2009 SS\TC's
I've heard that they will deform over time as well , just the nature of the material they are made of. I've had it at the track a few times and have had them in for almost a year now and I still am rid of wheel hop while running more power than when i started. For the price of them I don't even care if I have to replace them every so often.
not to mention what are you looking for? as far as the TC goes?
Last edited by SloBaLt RiDeR; Jan 23, 2009 at 02:11 AM. Reason: Automerged Doublepost
i had my ingals no problem for a whilleeeee now but I do want to go with the motor mount when i sell my ingals. so quick question motor mount will take out the wheel hop like the ingals does correct?
the vendors IMO have been making good progress already... air intake, cracking the computer little by little, turbo swap, intercooler, charge pipping... i mean what else are you looking for
want the wheel hop gone.... go to OTTP and get the Reverse mounts..ill keep saying it... end of story
Last edited by SloBaLt RiDeR; Jan 23, 2009 at 02:16 AM. Reason: Automerged Doublepost
why do people have to blow **** up like this really? ok i understand your giving you opinions my fellow cobalt people but to bash a company about one little effin thing? that's just plain stupid and watch if some of us keep it up all the good deals go away. sorry aaron you gotta hear all this stuff about the company you work for. i have my stiff on correct but im going to buy my solid motor mount after my little daughter is born. enough said. lock this thread. besides even if he said you should buy it because some tend to bend is just a-ok in my book. all this person had to do in the first place is say oh ok perhaps later on. but NOOOOO always gotta blow stuff out of context. im tired of this bs. just leave it as it is please.
i had a toruque damper on my old car and never bent the brakets or anything like that
but the motor mount is better reason being cuz the damper acts like a shock/damper so it'll eventualy go out
i had my ingalls on for 3 years and almost 60k miles, until i did the turbo conversion and didn't have anymore room for it, i had solid mounts as well. the only thing i see as a problem with stiffening the upper mount is nobody addresses the otherside being the top tranny mount(it's hard as hell to get to) but if your gonna stiffen up just one side then what kind of stresses are you putting on the other top mount? and is it causing the motor and tranny to twist to one side? i say just stick with the lower tranny mounts and leave the top two mounts alone till someone comes out with a suitable upgrade for the top tranny mount. just my .02
lol ill look into that but with my td I DONT have any wheel hop lol thats y I wanna make sure its gonna be thte same with the mount if I was to get it if not ill keep the td
i would buy it if there was an upgraded drivers side mount.
Iceberg
Sep 29, 2015 12:33 PM
