installing extended studs on front hubs
i replaced my rear studs with arp 7708 extended studs and now want to do the front. but ive heard that i will need to remove my hubs to fit them in? is this true or not. i want to know what to expect
bearing must be removed. stock stud length is not possible without mods, longer is impossible. There is a dimple in the wheel bearing housing to assist. Use the correct tool to pull the studs through. Good luck.
