Jerky steering problem low speed.
Old Apr 6, 2016 | 10:05 AM
chuckie's Avatar
Hi ,
The past few days I have noticed at low speed the steering seems jerky, no warnings or codes. I have heard, alternator, strut mount bearing, suspension issues. I am lost, any tips? Thanks in advance.
Old Apr 6, 2016 | 11:53 AM
Sl0wbaltSS's Avatar
Jerky steering? Like it's easy to steer then suddenly it's heavy and then light again?
Old Apr 6, 2016 | 12:05 PM
chuckie's Avatar
Yes mostly noticeable at a stop or low speed.
Old Apr 6, 2016 | 02:39 PM
Kobraa's Avatar
Had a customer ion doing that last summer. Would get to a certain point turning at a stop or low speed and get stiff af. Put a rack in it to fix it.
Old Apr 6, 2016 | 02:42 PM
chuckie's Avatar
This is more random..sometimes as soon as you try turning other times as you go around a corner it doesn't return well...I pb blasted the intermediate shaft and will try that first.
chuckie's Avatar
thanks to you both for answering BTW...much appreciated.
Old Apr 6, 2016 | 02:48 PM
Kobraa's Avatar
Ya, thats the way his was. I could watch the power steering motor voltage on my tech 2 and it would get to the point where it was stiff and the amp output on the power steering motor would ramp up and come back down. And once the motor got hot from working so hard it would get worse and worse.
Old Apr 6, 2016 | 02:53 PM
chuckie's Avatar
ok thanks if the PB blaster doesn't work will see about that next..
yellow_cobalt
Feb 17, 2022 11:33 PM
ricklovin93
Turbo Tech Racing
Aug 23, 2017 05:35 PM
klotzy_550
Sep 14, 2016 04:25 PM
basebalt
Mar 27, 2016 02:09 PM
Raptorunbound
Mar 17, 2016 12:10 PM
