need help strut experts
Old May 15, 2015 | 12:48 PM
turboecotec02's Avatar
I'll start from beginning. Had new struts put on front. I should have did them myself. After I get my car back I have a clunking noise. I call him and tell him I think the strut mount on front left is screwed. He replaces it. Clunking is still there.
I've replaced cab on driver side and was getting ready to do ball joint. As I was jacking the car up I heard the clunking! So I let it drop fast and it repeats. The noise is coming from the top of the strut mount. When I had control arm off that whole strut moved like that top nut wasn't tight but I do not know what to do.
I was going to put a vice grips on the rod loosen the nut and put some washers in there. Sound like a good idea 1st?
Old May 15, 2015 | 02:33 PM
To the top
Old May 15, 2015 | 04:11 PM
northvibe's Avatar
have you verified the strut is seated and installed properly, also torq'ed to spec?
Old May 15, 2015 | 06:12 PM
No I have done nothing except start changing other stuff until I narrowed the noise directly to that top mount. I've never done a strut before
Old May 15, 2015 | 06:17 PM
Its not that complicated you have the strut connected to the endlinks, knuckle and the top with the 3 bolts. It could be that it wasnt seated correctly, or maybe something is loose from what i mentioned above
Old May 16, 2015 | 11:50 AM
Can someone tell me if this is the factory strut ? Looks really beat up for being brand new?
Old May 16, 2015 | 11:58 AM
Nevermind looms like a sensa **** brand
Old May 16, 2015 | 03:24 PM
Yeah it doesnt look oem
Old May 16, 2015 | 04:30 PM
Found the problem. Should have just did them myself. Wrong nut was used with a impact. Treads are gone on strut. Thanks guys
Old May 18, 2015 | 04:33 PM
northvibe's Avatar
did you go to a dealer or some shop?
Old May 20, 2015 | 01:55 PM
Went to a shop he used the old nut and put it on the new strut and stripped all the threads and still put on the car. It was loose as hell. New strut fixed it.
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Tupp
Sep 29, 2015 11:07 PM
