New ZZP front sway bar making noise
I wonder too :/ I gave up. Tried new links new bushings new clamps.
I have read there are two different types of control arms found on cobalts, steel and aluminum.
Aluminum being a little smaller in the sense it would provide more clearance than a steel control arm.
I don’t know anything I say is a grasp at straws.
Being a LAP engine, my vehicle has very little amount of info out there. Christ it probably took me 5 months to figure out my car was not an L61.
Prehpas in my exact vehicle there is something slightly different than another cobalt.
Prehaps zzp tested there bar on cobalts 2005-2008 LE5’s, L61’s, LNF’s LSJ’s etc and said “well if it’s fitting all of them so far, probably fits em all?”
I really don’t know
I really don’t know
Needles to say if anyone is reading this and has an 09 g5 And your thinking of upgrading your front bar. Go with a larger stock bar, Fe3 or Fe5.
As as someone said above, zzp bar is 26mm hollow
largest stock bar is 24mm solid
who knows maybe I was shipped the wrong bar, it looked like th picture the cruves matched to my underbody, but the ends of zzp’s bar do not resemble a stock bar.
Different sway bar geometry. Not to say it won’t work, but it didn’t for me.
Back to the stock bar now, no rattle glunk , my shocks took a beating threw it all.
but at the end of the day, I can hit a speed bump doing 20km/h all I hear is a faint *squish not BOOOOOM-GLUNK-SMASH-CRASH-CLANG-ScREEEeE
yes the car understeers a little bit but I can’t enjoy driving. Turn up the music and not have to worry that my sway bar is gonna take out a trans mount on the road
If you want less understeer and more oversteer you want a rear bar. Many recommend not going any stiffer than the FE5 front bar for body roll anyway because once you exceed that stiffness it adversely affects the handling by promoting more understeer. Look into a Powell hardcore rear bar or OTTP's rear bar. It just bolts to the rear twisting beam and is easy to install.
