The OFFICIAL Coilover Thread
Old Apr 17, 2013 | 12:52 PM
  #226
RandyO's Avatar
Originally Posted by EvilBananaWind
wow...that is amazing.
How does one's tires not rub on the body whenever you turn?
Also how is the ride quality when you are this low?
Mini tub upfront and pulled the **** out of my front fenders. lol But before these wheels they rubbed like a 12 year old when his parents arent at home.
Originally Posted by matt638
Meh, it'll do for now.
This car looks like it is from the future.
It is, I am the space wizard.
Old Apr 17, 2013 | 12:53 PM
  #227
Originally Posted by Melon
Asked same thing. Verdict seems to b not necessary but do help a little bit along with help from their intended purpose
well said
Old Apr 17, 2013 | 01:10 PM
  #228
EvilBananaWind's Avatar
"Mini tub upfront"
Can you explain? Google search didn't help...
Old Apr 17, 2013 | 01:24 PM
  #229
maybe its rub not tub hahha
Old Apr 18, 2013 | 01:49 AM
  #230
RandyO's Avatar
I removed metal from the inside of the fender well and made it wider so my tires wouldn't rub when I went full lock. Took a good chunk out of my front tires before I had the chance to tub the front end. lol it's not really needed until the tires start to rub unibody. Only other person that had to do it besides me was Mike.
Old Apr 18, 2013 | 02:07 AM
  #231
rhamilton909's Avatar
How easy do coilovers blow or what's a good one that won't blow? Live in new England. Streets suck
Old Apr 20, 2013 | 09:59 PM
  #232
Originally Posted by 07cobaltLScoupe
so you have a base model? it all depends on what size wheels/tires you have too...
my LS with Megan Racing Street Series coilovers all the way down WITH lock rings still installed and 205/60/15 tires... on this set-up i have about 1 finger gap up front and 1.5/2 finger gap out back, any lower and i would need rotated trans mounts to help my axles although i might get them anyway
my wheels are 205'35 i think or something like that with rim size 17. its a low pro tire. top of tire is maybe 2.25 inches from top of rim. i know that much for sure. im jsut looking to go as low as possible without rubbing
Old Apr 20, 2013 | 10:19 PM
  #233
07cobaltLScoupe's Avatar
if your tires are 205/35/17 you're going to have a little more wheel gap than me because even with a 17" wheel that size is a smaller radius than stock, which means your speedometer/odometer are off more than the recommended numbers as well. but you will technically be lower, i'm more about less wheel gap than actually being lower
Old Apr 20, 2013 | 10:50 PM
  #234
i think thaTS what it is. i know the second number is 35/r17 jus tnot sure about first one. but the overall diameter is same as stock. im looking to close the gap as well but hoping to go lower too at same time
Old Apr 21, 2013 | 01:04 PM
  #235
What coilovers or suspension set up should I get and how low could I go
Old Apr 23, 2013 | 04:15 PM
  #236
AARON-SS-TC's Avatar
i just recieved some B&G rear adjustable shocks. What level do I set it at (1-12) for stiffness if i have them maxed out lowered?
i was thinking somewhere aound 4 since i am using H&R sport springs on my tc.....
Old Apr 26, 2013 | 05:52 PM
  #237
So I was walking across the street the other day and these were just lying on the ground.
And by walking I meant I ordered them, and by lying on the ground I meant that I picked them up from Alan @ TH Motorsports.
Old Apr 26, 2013 | 05:57 PM
  #238
mufinman007's Avatar
nice how low u planning on going ?
Old May 1, 2013 | 04:24 PM
  #239
Not sure. I measured from the pinch weld at the jack points and it was currently ~7.5-7.75 inches.
I am happy with that distance.
Just curious is there a standard place to measure on this forums when referring to ride height?
Old May 1, 2013 | 06:47 PM
  #240
alot of us measure from the top of the wheel well(center) to the ground
Old May 1, 2013 | 11:18 PM
  #241
RandyO's Avatar
^ This, otherwise known as FTG (fender to ground)
Old May 2, 2013 | 11:47 AM
  #242
Cobe's Avatar
Originally Posted by RandyO
Custom BC Coilovers
Can still go lower
Dude im speechless hahahaha. That thing is so ******* sick hahaha.
Old May 6, 2013 | 11:57 AM
  #243
Question...
With my stance's in the rear come some springs. With said springs there is a threaded body with two collars on them. With my car's rear jacked up, do I just thread them up to help keep the springs from coming off with the control arm fully drooping? Should there be preload?
Sorry, but I did search and couldn't find an definitive answer, or maybe I wasn't phrasing the question correctly.
I've already adjusted the shock body for ride height, I just want to make sure that I am not over/under compressing the springs.
Also curious, what would happen if I lowered the car without the springs on? Would that just slam the shocks down completely and be a big no no?
So I decided to get the cojones up and just jack the car up and start tinkering...
1 day later I got everything installed and it rides great at neutral adjustments. I also installed some powergrid endlinks while I was at it.
I will upload some photos later. I actually found that the one of the front left upper strut mount bolts was loose and just spinning inside the top portion.
That made for a effing wonderful time removing the old strut.
Last edited by EvilBananaWind; May 8, 2013 at 12:50 PM. Reason: Finished installing coilovers.
Old May 9, 2013 | 03:46 PM
  #244
Manopka's Avatar
Quick question: If I were to buy koni struts and then i bought a coil over system that didnt include struts like ground control or something, how would they compare to the complete coilover systems like stance, ksport and D2?
Old May 13, 2013 | 10:25 PM
  #245
how do you know what is the correct height for the rear shocks? fully compressed or fully extended?
Old May 14, 2013 | 01:40 PM
  #246
You should keep the shocks off the rear. Install only the springs (the springs can hold up the vehicle weight easily). Adjust for your ride height accordingly. Then adjust your shocks to match, but add 1 inch extra.
This was according to Stance directly. Spoke with Mike on the phone there.
****edit
Just spoke with John over at stance and he said you could also install an alternate way.
Same as before, let car sit just on springs, adjust the collars on the set piece for ride height, then jack up the rear control arm so that you have roughly 1" of spring compression.
Install the shock.
Repeat for the other side.
The shocks should be fully uncompressed when installing AARON. Shoot me a private message if you want me to explain in more detail. I just performed this procedure within the last week.
Old May 23, 2013 | 04:51 PM
  #247
BLK05SS's Avatar
does that silver one with Stance GR+ have wheel spacers?
Old May 23, 2013 | 04:56 PM
  #248
BLK05SS's Avatar
where can you find wheel spacers like the ones on that silver one with Stance GR+?
Old May 27, 2013 | 09:34 AM
  #249
727's Avatar
727
Megan Racing EZ Street MR-CDK-CC06-EZ
Stock SS SC with Aftermarket
Result - Front at "Medium" position & Rear at "Maximum UP"
Old Jun 23, 2013 | 08:23 AM
  #250
91RS's Avatar
Does anyone have an opinion on which brand has the best ride quality? I do NOT want it so stiff it rattles my teeth whenever I go over a bump. I like the Stance because of it has the adjustment for the ride height. I want to be a little lower (and definitely level), but I am not going to be slammed or running tons of negative camber. I have Kbee coilovers on my Trailblazer SS and it rides better than stock so I'd like to go the same route here. It was a little easier to choose a brand for the Trailblazer because there's only two to pick from!
