POssible bad lowering spring install
Old Sep 14, 2011 | 08:31 AM
Shogokuma's Avatar
is there a way someone can show me a picture of the orientation of the tabs im all confused and i dont know where they have to point out im experiencing a shutter under accel at low speeds on the passenger side.
on the strut itself
i drive a 06 cobalt ss /sc with SSC prints and 09 LNF struts
Old Sep 14, 2011 | 08:39 AM
blake05SS's Avatar
when u lower fwd most the time they shutter at low speeds mine does it and my buddys g5 does it
Old Sep 14, 2011 | 08:44 AM
Shogokuma's Avatar
its super annoying is it fixable with a front rotated zzp trans mount? and rack spacers?
Old Jan 18, 2012 | 09:01 AM
breds2k's Avatar
Got out the shovel, doing some research before i install my megan springs on my 4dr ls today. Is this shudder going to happen? I havent heard to much else about it.
Old Jan 18, 2012 | 09:08 AM
drumrush's Avatar
It sounds like wheel bind. I might have it, but its hard to tell because of my solid engine mount
Old Feb 4, 2012 | 11:05 AM
Shogokuma's Avatar
i think its my strut mounts since i used the ones from the junkyard instead of my own the day it got installed i noticed it.
Old Feb 4, 2012 | 11:15 AM
klloyd's Avatar
If the car is too low then you will get axle bind. I had the same issue on my 07 if I went to loow when I had the Stance coilovers. Now that I went to Eibach Sportlines its gone, car just might be a little too low.
Old Feb 4, 2012 | 04:44 PM
victoryredturbalt's Avatar
r the tabs in mounting area on top of strut (bump stop, bearing, mount assembly has a metal tab on it) on ur front struts facing towards the engine? if not could b ur cause.
Old Feb 4, 2012 | 05:21 PM
the link below may help
https://www.cobaltss.net/forums/susp...n-issue-84325/
https://www.cobaltss.net/forums/sear...archid=5076975
Old Feb 5, 2012 | 12:30 PM
Shogokuma's Avatar
thanks man im gonna try that
Old Feb 5, 2012 | 12:42 PM
Shogokuma's Avatar
too bad that picture dosent work, i bet thats my problem, i only feel vibration on the passenger side
Old Feb 5, 2012 | 12:45 PM
SilverSS_TNR's Avatar
yea def sounds like wheel bind, i had my 06 dropped pretty good on H&R springs and it was slammed pretty good and i got wheel bind, i put the same springs on my 09 and it didnt drop as much and i didnt have any wheel bind, but what your describing sounds exactly like wheel bind
Old Feb 5, 2012 | 05:54 PM
dakotaspeir's Avatar
#cobalthoes
so 06s go lower than 09s with h&rs? Im looking into the h&rs for my 09 tc but Ive heard too many horror stories about axles
Old Feb 14, 2012 | 02:25 PM
Shogokuma's Avatar
i have the struts from 09 and shocks on mine
Old Feb 14, 2012 | 02:34 PM
breds2k's Avatar
any recent confirmations that this works? anyone with a non-ss tried this?
bigdeertz
Nov 17, 2016 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Tupp
Sep 30, 2015 08:18 PM
