Possible Pedders Problem on 2010SS?
Old Sep 9, 2012 | 07:06 PM
ckt's Avatar
ckt
2010 SSTC, installed Pedders springs just about 3 weeks ago. Today, leaving the grocery store, a creaking/crunching sound was noticed on the rear passenger side going over speed bumps. This was the first time this noise happened. Decided to take pictures of right-rear spring. Is this wear normal? I assume the sound is not?
Old Sep 9, 2012 | 07:10 PM
BlackLsCoupe's Avatar
you no cut bump stop? i see nothing wrong. my clunks all the time. did it stock
Old Sep 9, 2012 | 07:22 PM
ckt's Avatar
ckt
No, nothing was cut. Is there some benefit doing that?
Old Sep 9, 2012 | 07:33 PM
TommyP's Avatar
AWD > FWD
You don't wanna cut bump stops. No matter how low you go. They're there for a very good reason. They save your shocks, and actually make your ride smoother. Impacts will be less harsh with the bumpstops in. They themselves act like a spring with a progressive rate, the progressive rate just goes to infinity very quickly.
Old Sep 9, 2012 | 08:16 PM
ckt's Avatar
ckt
@Tommy P, word. I figured.
Old Oct 14, 2012 | 07:02 PM
395 plus's Avatar
As some people that had pedders the coils can come together on bigger bumps causing a clunking noise. I put vinyl tubing on mine to stop it. Dont have that car anymore and the new one has YYZ on it.
Old Oct 14, 2012 | 07:47 PM
tpete763's Avatar
isn't creaking usually from bad struts/shocks?
Old Oct 14, 2012 | 10:19 PM
TommyP's Avatar
AWD > FWD
Not necessarily. The coils on the springs can rub together to make a creaking noise, and TC struts often creak when it's cold out. Mine always did, even when I got the car with 10k miles on it.
Old Oct 14, 2012 | 10:23 PM
tpete763's Avatar
Ahhh, thanks for the clarification, my struts always creaked in the back when its cold out since I got my car with 30k miles, I'm at 87K now and they still do it lol
turbochargedss2012
Sep 20, 2023 12:17 PM
deviance
Nov 24, 2015 05:51 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
