Preloading?
Old Aug 28, 2011 | 11:39 AM
Chuckd07's Avatar
Preloading?
I read alot of people talking about preloading their frontend for track use but can't find any threads about what it actaully means or what it does for your suspension? Any help on what it is and why it helps?
Old Aug 28, 2011 | 03:30 PM
Wangspeed's Avatar
There are 2 things you can preload. Either the springs in a coilover system, or the swaybar end links, if they're adjustable length. The end result is a car that will turn better one direction than the other. Don't mess with it unless you know what you're doing. Neither should be preloaded.
Old Aug 28, 2011 | 04:58 PM
majourpain's Avatar
unless he is talking about preloading the front struts for drag racing? Cmiller did that with chains so the car wont lift the front from a dig
Old Aug 28, 2011 | 06:07 PM
Chuckd07's Avatar
yeah im not looking to do it i just wanna know what it means? i like to learn stuff so i dont talk about stuff i dont know.
Old Aug 29, 2011 | 09:21 AM
06cobalt racer's Avatar
the chains acted as limiting straps preventing full extension. preloading is different. preloading is basically making the spring stiffer. if i am wrong someone please correct me. i dont want to give out false info.
Old Aug 29, 2011 | 09:24 AM
maybe this means what sum ppl do, wich is put mini footballs stuck into the rear springs so the car doesn't bog down in the back when u take off?im not sure how good that works tho i dont think a m ini football would do **** lol
Old Aug 29, 2011 | 09:30 AM
it really works very well!!! take a peewee football stick it up there and inflate to 40-50 psi. jacks the rear up and you will have very little to zero squat!!!
Old Aug 29, 2011 | 09:38 AM
U just shove it into the springs somewhere and then inflate?
Old Aug 29, 2011 | 10:18 AM
Yup that's right. Jack the rear up so the spring is extended and have the football deflated and wiggle it in. Corners of the ball should be vertical. Lower the car back down then just inflate the football. I used to just leave them in the springs at all times. Just inflated them when I got to the track and deflated before I left.
Old Aug 29, 2011 | 10:43 AM
man thats awesome i never would have thought they could withstand that kind of weight and stuff lol! how is it driving with them around town if u leave them inflated?
Old Aug 29, 2011 | 10:53 AM
I did I once. I wouldn't recommend it. Very very rough driving. Your basically driving around with no rear springs or shocks.
sjc0013
Apr 30, 2022 02:26 PM
Badmunky
Mar 16, 2015 12:13 PM
BlkWdoSS
Drag Racing
May 4, 2009 05:05 AM
