Rear Camber
Old Sep 26, 2012 | 02:08 AM
10Cobalt_SS's Avatar
Rear Camber
is there any adjustment for rear camber for the cobalt ss??? getting coilovers soon and dont wanna wear tires down too quick
Old Sep 26, 2012 | 11:01 AM
noorj's Avatar
You need to shim the rear hub to get camber on our cars. Any decent alignment shop should be able to do this no problem. Just make sure not too get much at all, it will upset the car's handling characteristics.
Old Sep 26, 2012 | 11:07 AM
kzak104's Avatar
you wont change camber by lowering the rear, just camber in the front.
Old Sep 26, 2012 | 11:35 AM
D Boogie C's Avatar
wish someone would come out with a rear camber kit for the cobalt :|
Old Sep 26, 2012 | 11:39 AM
JacBlackSS/TC's Avatar
solid rear so therefore it won't happen without shimming, also toe is what effects tire wear not camber, get a proper alignment and you tires will wear fine.
if you aren't getting stance coilovers you aren't won't be that low anyway
Old Sep 28, 2012 | 09:34 AM
CptProzak's Avatar
Excessive camber will cause increased wear on the inner/outer edge of the tire, you may be thinking of caster
Old Sep 28, 2012 | 03:43 PM
noorj's Avatar
Not in the rear. Like that other guy said rear torsion beam will not cause tire wear due to camber. Should have mentioned that before, sorry.
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Delta coupe
Sep 30, 2015 08:11 AM
