Rear Camber
You need to shim the rear hub to get camber on our cars. Any decent alignment shop should be able to do this no problem. Just make sure not too get much at all, it will upset the car's handling characteristics.
solid rear so therefore it won't happen without shimming, also toe is what effects tire wear not camber, get a proper alignment and you tires will wear fine.
if you aren't getting stance coilovers you aren't won't be that low anyway
Excessive camber will cause increased wear on the inner/outer edge of the tire, you may be thinking of caster
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
