Rear coil spring replacement
Old Mar 2, 2013 | 01:54 AM
charged2005SS's Avatar
Can I get a step by step without a spring compressor.
Old Mar 2, 2013 | 05:19 AM
BLue NoTe's Avatar
This is so simple, one of the pain free jobs balt owners enjoy.
Jack the car up (NOT on the twist beam) put it on stands, remove wheels, undo bottom shock bolts and lower twist beam until you can wiggle the springs out. Reverse to reinstall, no compressor needed. I'd recommend that when you have the car up on jackstands support the twist beam so when you take the shock bolts out it doesn't just drop and hang. I place a piece of wood on my floor jack and lower it manually.
81 lb/ft torque spec when you retighten the shock bolts btw. Have fun
Old Mar 2, 2013 | 05:43 AM
Cherry GT's Avatar
I would remove the bolt that holds the brake line bracket to the body on each side, allows you to lower rear beam more and makes it easier to remove springs. It takes a 10mm wrench to remove.
Old Mar 2, 2013 | 01:12 PM
so its not a dangerous job. and i have a hoist i can do it on there and then ill just use a transmission jack.
Old Mar 2, 2013 | 01:39 PM
nobody2u's Avatar
Reason not to jack it up on the twist beam? That's what I do normally before putting the stands on haha.
Old Mar 2, 2013 | 01:47 PM
BPacak's Avatar
Vtec Rep
how you gonna get the springs out if thats what your jack is on haha
Old Mar 2, 2013 | 02:23 PM
nobody2u's Avatar
Jack is removed then reapplied to support it once the stands are on. Car rests on the stands. It's only to get the ass up in the air haha.
Old Mar 2, 2013 | 05:43 PM
BLue NoTe's Avatar
You don't want to damage it. It's not meant to hold that load and once its bent its done
Old Mar 2, 2013 | 05:45 PM
Powell Race Parts's Avatar
check the torque spec thats for the top bolt not the lower. Top bolt is easier to remove. People sometimes cross thread the lower bolt as it doesnt fit straight... removing the brake line clip is a good fail safe plan...
Old Mar 2, 2013 | 11:27 PM
BLue NoTe's Avatar
Last sticky I read was 66 top 81 bottom but ur the man
Old Mar 3, 2013 | 07:51 AM
i guess I will check the book. moment..... you are right, my bad
Shock Bolt Lower
110 Nˇm
81 lb ft
Shock Bolt Upper
90 Nˇm
66 lb ft
Old Mar 3, 2013 | 09:42 AM
Josh171's Avatar
good info. i need to do this soon. just got some TC springs to upgrade to on my lsj.
Old Mar 3, 2013 | 10:04 AM
that will trim 10 mm lower its a good choice; buy some new struts and shocks from CED really good prices, you will be done for a while
ps you may need new control arm bushings, I have an upgrade for 199 a pair...( had to make the sales pitch lol)
Old Mar 3, 2013 | 11:18 AM
OBZ's Avatar
OBZ
Definitely be careful with that bottom bolt. I didn't..
Old Mar 3, 2013 | 04:00 PM
Josh171's Avatar
thanks for the heads up. good chance i may need it. and ill be sure to take care with that bolt.
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
