Rear FE5/FE3 springs
It would lower the rear for sure. I'm not too sure how the front and rear spring rates would work together. IIRC the SS/SC and SS/TC FE5 spring rates are quite a bit higher than the FE1 spring rates.
i have fe3 front and rear springs give um to ya for 50
where are you located im in sebring how far are you from sebring instead of shipping
a good bit like 90 thousand car has cut ss/sc springs on it but up to 90 thousand didn't see any difference from when they were new in 2005 so they are still good possibly buying an ss/tc soon from lakeland
Fe 1 sets a ride height. whatever it is, (4 x 4 mode) Fe3 trims 10 mm less; FE5 for the LSJ sc trims another 10mm lower; FE5 for LNF turbo trims another 10 mm less. The spring rates for FE3 and FE5 are stiffer, of the two FE5 variants the LNF is slight stiffer than the LSJ, and of course you gain a little stiffness by shortening the spring...
DANRICKARD
Oct 1, 2015 12:08 AM
