Service Traction/ESC Off/ABS Light
Old 04-23-2012, 11:22 AM
user 72239's Avatar
Well, I installed CM springs this weekend and on my way home my ABS light and Traction light came on, along with my ABS light. I tried pulling my battery to see if it was stuck but its still on. I am going to check the ABS sensor on each wheel when I get home, but I dont know what to do about the Traction/ESC. Any suggestions?
Old 04-23-2012, 11:25 AM
Resident Post Whore/Troll
07SSYellow's Avatar
probably just a sensor unplugged on the front end. and when the ABS light comes on it throws codes for TC/and ESC too because there all tied into one system.
Old 04-23-2012, 11:41 AM
user 72239's Avatar
oh sweet, ill check that when I get home. Thanks Joe
Old 04-23-2012, 11:45 AM
07SSYellow's Avatar
anytime bro text me if you need any help!
Old 04-24-2012, 05:45 PM
user 72239's Avatar
Fixed, you were right Joe. I forgot to plug in the drivers side front sensor.
Old 04-13-2014, 06:21 PM
ShawnW117's Avatar
Bumping an old thread instead of making a new one...I'm having the same problem but mine are plugged in. Got it scanned and said bad wheels speed sensor left front and left rear. Bought some used replacements on ebay. Lights are still on. No noticeable problems with the wires. Any ideas? Maybe my replacements are bad too? Any help would be appreciated.
Old 04-14-2014, 10:45 AM
user 72239's Avatar
Usually if they stay on it means bad wheel bearings. Either the line was cut or it just went bad.
Old 04-14-2014, 11:13 AM
soaxin's Avatar
Check the wire harness on the car. also Could be a bad part especially if its used.
Old 04-17-2014, 01:27 PM
wollis1's Avatar
Same problem here. Gonna jack up the car later and check it out. Buddy of mine read the code and it looms like a bad sensor on the front passenger side. Just replaced the hub too... Grrrr
Old 05-01-2014, 11:14 AM
wollis1's Avatar
Looks like it was just a bad sensor in the hub... Replaced it and everything is running fine. No relearn necessary since you can't reset it using code reader. It reset itself.
dennis69
10-20-2015 04:49 PM
patooyee
10-15-2015 05:11 PM
importkiller
09-30-2015 07:18 PM
z28addiction
09-28-2015 12:03 AM
grampss
09-27-2015 08:51 PM
Quick Reply: Service Traction/ESC Off/ABS Light
