Sportlines, cutting bump stops, shocks?
Old May 19, 2010 | 10:46 PM
ZZRider618's Avatar
Ok i have been reading on this a while and have seen many mixed reviews, I have a 07 SS/SC with Sportlines, I did NOT cut the bump stops and my car feels like its getting hit by a wrecking ball when i hit a bump in the road. Now is this from my lack of cutting the bump stops, or is this becuase i need to buy new shocks all the way around that are made for the lowering? IF that is the case, what are some recomendations/places to get some shocks, or will just trimming the bump stops soften up the ride a little?
Old May 19, 2010 | 10:48 PM
EdCobaltSS's Avatar
thats because of the bump stops
cut them
Last edited by EdCobaltSS; May 19, 2010 at 10:48 PM. Reason: Automerged Doublepost
Old May 19, 2010 | 10:51 PM
ZZRider618's Avatar
cut them
Is it recommended to purchase new shocks after lowering or are the factory GM ones well up to par?
Old May 19, 2010 | 10:52 PM
EdCobaltSS's Avatar
i had my car lowered on factory shocks/struts, other than adjustables, stock is fine
Old May 19, 2010 | 10:59 PM
ZZRider618's Avatar
Ok will do the cutting tomorrow and Post back, thank you for the speddy response.
one last ??? is it possible to cut without disassembly or do i need to take springs off again?
Last edited by ZZRider618; May 19, 2010 at 10:59 PM. Reason: Automerged Doublepost
Old May 19, 2010 | 11:01 PM
EdCobaltSS's Avatar
you should be able to cut without removing from what i remember
Old May 21, 2010 | 06:48 AM
ZZRider618's Avatar
Well the front ones were simple to cut with just a razor knife, the rear ones i had to take back off agian to do but it took like 5minutes to take the srpings off, real easy and it did make a HUGE differnce. thank you for the replies...
Old May 21, 2010 | 09:20 AM
EdCobaltSS's Avatar
glad i could help, and glad to hear it solved it
Old May 21, 2010 | 11:29 AM
Bumpin Balt's Avatar
I left my bump stops uncut at first also. There was very little suspension travel. I have since cut the front ones in half and the tapered tip off of the rears (~1/2"). I checked to see if the struts would bottom out with the halved stops and they didn't. I think a lot of people make the mistake of cutting too much off the rears and then they have issues with rubbing when they try running 235 tires. If you plan on running 235's, I would leave the rear stop uncut or just take the tip off like I did.
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Tupp
Sep 30, 2015 08:18 PM
Sep 27, 2015 08:53 PM
