SS/TC Front and Rear Brake Pad and Rotor Setup
Old Mar 4, 2014 | 08:24 AM
blu3_v1p3r's Avatar
I'm just wondering what you guys are running for brake and rotor setups on SS/TC's. I just bought the car its on the OEM rotors and pads, I just feel like pretty soon the breaks will be at their limit. Let me know what combinations you guys have, and how much noise they make.
Old Mar 4, 2014 | 03:33 PM
m33pm33p's Avatar
Stock is best for stopping power/bite/performance
hawk pads might produce less dust but don't grab as well
Anything else is either track only or similar to hawks.
Don't cheap out, I went through $60 lordco pads for the front in under 20k. Yes I like braking.
Old Mar 4, 2014 | 04:12 PM
LNFTX's Avatar
^ this
Stock
Stock
Unless you track the car hard
If you do the brakes youself pay close attention to properly cleaning and lubricating everything prior to install
Stock on this car is high quality pad material is the same as on ctsv and others
Rotors are pretty good lots will recommend r1 and they are great but stock pads are aggressive and from what ive seen will eat any rotor thru 1 pad life so I dont see the pount in paying twice as much unless you gotta have slotted rotors
Old Mar 4, 2014 | 05:04 PM
thecutlip's Avatar
I went hawk pads and powerslot rotors, those cool slots.
A little cheaper then oem, but still pricey. Works fine for me, I didn't notice a huge difference. Also I hate how much brake dust the oem pads create.
Old Mar 4, 2014 | 09:11 PM
I plan on going with R1 concepts and Hawk pads.
Old Mar 4, 2014 | 11:20 PM
blu3_v1p3r's Avatar
I think I'm going to plasti-dip the stock rims white, so less dust would great... I'm only going to Plasti-Dip them white so I can get feel for I like them before I go and get them powder coated.
Old Mar 4, 2014 | 11:26 PM
cobaltss#01's Avatar
I tried thermo quiet pads in the front and they suck. There supposed to be ceramic but they looked more like semi metallic. Some how there is metal in them.
Old Mar 5, 2014 | 09:39 AM
blu3_v1p3r's Avatar
So what would be the best place to get OEM rotors and brake pads?
Old Mar 5, 2014 | 09:42 AM
umrdyldo's Avatar
Well if you like supporting vendors: Crate Engine Depot.
If you have Amazon Prime, amazon is by far the cheapest. Will save over $100 or more
Old Mar 5, 2014 | 09:48 AM
blu3_v1p3r's Avatar
Anyone use the Powerstop Evolution Ceramic Plus brake pads, and powerstop rotors?
Old Mar 5, 2014 | 09:51 AM
blu3_v1p3r's Avatar
I do like to support our vendors as much as possible, but if there is difference of over $100 Im afraid I have to take the deal that saves the money... if it was like $5, $10 even $20... it wouldn't be that bad... but $100 keeps gas in the car for 2 to 3 more weeks.
Old Mar 5, 2014 | 10:00 AM
blu3_v1p3r's Avatar
Well after looking at the OEM brake pads price, I've decided that I'm probably going with something after market... powerstop as far as I know has a pretty good reputation, so I wold expect their products for the cobalt to be just fine. I can't see spending $173.00 for front brake pads... I thought $60 was a lot for pads for my 2.2....
Old Mar 5, 2014 | 10:08 AM
umrdyldo's Avatar
2 Rear Rotors - $82
Robot Check Robot Check
Rear pads $50
2 Front Rotor $88
Front Pads $108
And we aren't talking about a base model. This SS/TC came with some stout brakes up front. Don't cheap out.
Old Mar 5, 2014 | 10:18 AM
RyBread761's Avatar
2 Rear Rotors - $82
Robot Check
Rear pads $50
Robot Check
2 Front Rotor $88
Robot Check
Front Pads $108
Robot Check
You sir, are a boss. Thanks for the links!
Old Mar 5, 2014 | 10:22 AM
blu3_v1p3r's Avatar
So through Amazon... its less then $250 for everything... and through CED its 250 for just the F&R Pads...
And I suppose your saying powerstop is no good for the cobalt? Why is that? I've never heard anything bad about their stuff for any car?
Old Mar 5, 2014 | 10:34 AM
umrdyldo's Avatar
No i have no experience with Powerstop. They may be great, but the stock front pads are arguably the best there is for our car. People don't like them because of cost and dusting, but there is a reason for that and it's because they are top notch.
How much are the Powerstop front pads?
Old Mar 5, 2014 | 05:12 PM
blu3_v1p3r's Avatar
fronts about $55. rears are about $25.
Old Mar 12, 2014 | 03:32 PM
SSnRXP's Avatar
2 Rear Rotors - $82
Robot Check
Rear pads $50
Robot Check
2 Front Rotor $88
Robot Check
Front Pads $108
Robot Check
You are awarded many internets good sir! I didn't really dive that deep into searching on Amazon. Not the easiest to search on there for these parts. Where were you able to look up the AC Delco part number? There is the OEM number, which is easier to find, but not the AC Delco part number.
Old Mar 12, 2014 | 03:43 PM
umrdyldo's Avatar
I took the number right off CED's website and put it into Amazon. I have bought and installed those and they are for sure AC Delco parts.
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
