SSC springs/shocks weight limit?
Old Feb 16, 2012 | 06:26 PM
scottyguy401's Avatar
Hey everyone, I'm moving to socal on saturday and need some help on what the weight limit is for the ssc springs/shocks. I just got done loading all of my stuff into my car and every square inch is packed with my stuff. Seeing my car drop another 1 1/2 in. in the back end has me a little worried. It looks awesome being slammed, but I'm starting worry my suspension is gonna give out on me during my 4 1/2 hour drive to socal. Anyone have any information on how much extra weight I can put on the suspension?
Old Feb 16, 2012 | 06:30 PM
And a picture to show off hehe
Old Feb 16, 2012 | 07:07 PM
07cobaltLScoupe's Avatar
truthfully i think you should be fine. i have the eibach pro- kit on my car with stock shocks/struts and i moved all of my things from home to college and vise- versa a couple times over a 3hr drive and never had a problem, a little bouncy and touchy at times but that was it. when i was in a dorm i could get everything in my car with the trunk packed full and my back seats down and that whole area full of totes packed with all my clothes
Old Feb 16, 2012 | 07:17 PM
TommyP's Avatar
AWD > FWD
I'd be a bit nervous at that level your gonna be riding the bumpstops already
Old Feb 17, 2012 | 01:40 AM
Cobalt08LS's Avatar
damn.
Old Feb 17, 2012 | 01:43 AM
nobody2u's Avatar
Why is your back so low? Is that a result of the shocks?
Old Feb 17, 2012 | 10:15 AM
Gremlin85's Avatar
From what i understand, SSC's have a very similar spring rate to stock. The only thing is that you've lowered yourself on stock shocks so there is an increased chance of them blowing out from riding fully compressed like that.
Inside the door there is the specs for max capacity and load ratings. Be sure to put the proper pressure in your tires as well.
It's a chance but I think you should be okay if you take it easy and watch for big bumps and pot holes. You might actually just blow out a tire instead of the suspensions failing if hitting a big enough pot hole.
Just to give you an idea, I loaded up my 2004 GTO with everything I could when I moved from PA back to MA (almost a 6 hour drive) and that suspension sat just like yours. I had Zero issues but I had pedders zero drop springs - I was riding on bump-stops with it fully loaded though.
Old Feb 17, 2012 | 12:50 PM
Wangspeed's Avatar
Good chance your already worn shocks are probably dead after this
Old Feb 17, 2012 | 01:03 PM
jmfselu's Avatar
monroe shocks are 29.95 at o'reillys. Just fyi
Old Feb 17, 2012 | 01:52 PM
Well I still have my stock shocks/springs. I'm assuming the shocks i have right now are ssc, i just bought them off a local guy and he said they were ssc lowering springs so I don't know too much about them. I just now they lowered my ride a lot compared to stock.
bigdeertz
Nov 17, 2016 09:41 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
