Steering Rack Spacer
Old Nov 2, 2010 | 05:51 PM
averagewhiteboy's Avatar
Hey guys,
I'm lowered and was suggested to getting a steering rack spacer. It's nice and cheap, but how do you install it? Any how to's or anything? Will it help alot?
Thanks!
Old Nov 2, 2010 | 05:54 PM
CobaltVenomSS's Avatar
Originally Posted by averagewhiteboy
Hey guys,
Thanks!
also wanna know
Old Nov 2, 2010 | 05:56 PM
HB_SS/TC's Avatar
Undo bolts
Put spacer in
Put bolt back
Done
But for reals its easy if you look undernreath real simple install
Old Nov 2, 2010 | 06:02 PM
TurboTechRacing's Avatar
Originally Posted by HB_SS/TC
Undo bolts
Put spacer in
Put bolt back
Done
Yes...
Remove 2 bolts
Insert the spacer between the frame and the steering rack, at the 2 bolt locations
Re install the 2 bolts
And that is it. Takes around 30 minutes from my past.
Old Nov 2, 2010 | 06:04 PM
bbrewbaker's Avatar
Does the alignment need to be done afterwards? Or don't the angle of the tie rods change much?
Old Nov 2, 2010 | 06:09 PM
HB_SS/TC's Avatar
Oh yeah alignment afterwords too
Old Nov 2, 2010 | 07:22 PM
I need an alignment anyway..
Do you add it to it then or does it replace something?
Old Nov 2, 2010 | 07:28 PM
donkeyballs's Avatar
I need this info also I'm sitting pretty low What does this actually do ? I'm guessing it stops something from wearing.. Wish i knew more about cars
Old Nov 2, 2010 | 07:30 PM
redcobalt07's Avatar
it raises the steering rack back up to stock height
Old Nov 3, 2010 | 08:25 AM
Sorry, but anyone have a pic of where it goes?
It's supposed to help eliminate bump steer from being lowered..
Old Nov 3, 2010 | 09:35 AM
HB_SS/TC's Avatar
Old Nov 3, 2010 | 09:43 AM
BLAZIN07SS's Avatar
I'm too JDM for you
**note** thicker rack spacers will not work with the stock transmission mounts
Old Nov 3, 2010 | 10:09 AM
RoadconeTuning's Avatar
it changes the Ackerman angle...
Old Nov 3, 2010 | 11:39 AM
Wangspeed's Avatar
I don't think the ackerman angle has changed by adding the rack spacers. To do that, you'd probably have to relocate the rack or tie rods ends.
Old Nov 3, 2010 | 11:42 AM
QUICK QUESTION!! when i do u-turns with no throttle i dont get a cluncking noise...but as soon as i give it gas it clunks...
im lowered on progress springs
Old Nov 3, 2010 | 11:45 AM
Maupin SS/SC's Avatar
since i dont drive much i dropped about 25 miles ago lol cars been sitting if i order these and get them in and them get an alignment im fine right....actually nvm im driving 2 hrs this weekend i better get one!!!!!
Edit: wont place redo it if its "off" after a week
Old Nov 3, 2010 | 11:48 AM
Mudcrutch's Avatar
The spacers may not remove that -- it didn't for me. But the spacers DID remove grinding while turning at low speeds.
Old Nov 3, 2010 | 11:49 AM
Mudcrutch's Avatar
Another thread with good info: https://www.cobaltss.net/forums/how-...ing-r-r-23418/
Old Nov 3, 2010 | 11:50 AM
i just dont know what to replace on my car... axles or what
Old Nov 3, 2010 | 12:27 PM
hawlyns711's Avatar
what does this spacer actually do correct a problem or enhance drive ability?
Old Nov 3, 2010 | 12:43 PM
HB_SS/TC's Avatar
You guys have to do your own searching
Click here Steering Rack Spacers - Over The Top Performance
Old Nov 3, 2010 | 12:44 PM
do my seaching david!! lol whats my problem?
Old Nov 3, 2010 | 12:49 PM
HB_SS/TC's Avatar
I have enough clunks in my suspension can't help you there lol
Old Nov 3, 2010 | 12:52 PM
AHHHHHH!!!! i just want to know what to buy
idk if i need endlinks axles or what
Old Nov 3, 2010 | 03:31 PM
Win on that first link. I remember that old thread..
